Pulling the tape! http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=35339 |
Author: | NWflyonly [ Thu Feb 09, 2012 8:21 pm ] |
Post subject: | Pulling the tape! |
I just finished shooting the last coat of lacquer on the neck of my first build and was wondering when you pull the tape? My fret board is bound and I want to make sure that I don't inadvertantly pull the finish. Any help would be greatly appreciated! |
Author: | Tai Fu [ Thu Feb 09, 2012 8:29 pm ] |
Post subject: | Re: Pulling the tape! |
NWflyonly wrote: I just finished shooting the last coat of lacquer on the neck of my first build and was wondering when you pull the tape? My fret board is bound and I want to make sure that I don't inadvertantly pull the finish. Any help would be greatly appreciated! I pull the tape carefully while the lacquer is still wet... so that there is no chance for the lacquer to peel off. |
Author: | DannyV [ Thu Feb 09, 2012 9:17 pm ] |
I like to wait until I've had full cure and done the final wet sanding. I take it off prior to buffing. |
Author: | joe white [ Thu Feb 09, 2012 10:11 pm ] |
I leave the tape on until the very end after sanding and buffing. This way your fret board is protected from all the sanding and buffing crud. Just sand the edge of the fret board right by the tape to create a clean edge so that the finish can't peel off with the mask tape. |
Author: | Ken Jones [ Thu Feb 09, 2012 10:16 pm ] |
I like to unmask as soon as I've gotten all my coats on and they've dried overnight. I carefully score around all masks before removing, being careful not to cut into the wood itself. I find the longer I leave the fingerboard masked, the more residue there is to clean off. I find leveling to be much easier without the masks in the way, too. Ken |
Author: | joe white [ Fri Feb 10, 2012 12:13 am ] |
Ken Jones wrote: I find the longer I leave the fingerboard masked, the more residue there is to clean off. Ken Ken, If your masking tape is leaving a residue behind, it might be time to look into a better quality masking tape. |
Author: | Colin North [ Fri Feb 10, 2012 4:22 am ] |
joe white wrote: I leave the tape on until the very end after sanding and buffing. This way your fret board is protected from all the sanding and buffing crud. Just sand the edge of the fret board right by the tape to create a clean edge so that the finish can't peel off with the mask tape. +1! |
Author: | Ken Jones [ Fri Feb 10, 2012 8:52 am ] |
joe white wrote: Ken Jones wrote: I find the longer I leave the fingerboard masked, the more residue there is to clean off. Ken Ken, If your masking tape is leaving a residue behind, it might be time to look into a better quality masking tape. I use the 3M low-tack blue stuff. It's pretty spendy for masking tape, and does a good job, but it still leaves a bit of a pattern on the fingerboard. Easy enough to clean off, but just as a rule, I don't like to leave masking tape on any longer than I need to. |
Author: | NWflyonly [ Fri Feb 10, 2012 10:52 am ] |
Thanks guys I appreciate all the input! |
