http://www.luthiersforum.com/forum/
Dyed Epoxy
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=34952
Author:  Mike OMelia [ Fri Jan 13, 2012 11:56 pm ]
Post subject:  Dyed Epoxy
I want to fill a laser engraving with dyed epoxy, black or rust colored. Need resin brand and dye brand suggestions please. Thanks!
Author:  runamuck [ Sat Jan 14, 2012 12:35 am ]
Post subject:  Re: Dyed Epoxy
West System. I use tempera when it's not structural.
But don't over do it.
Author:  dpm99 [ Sat Jan 14, 2012 12:49 am ]
West Systems also manufactures a black mix-in dye that's not too expensive. It's to lower friction on boats, but hey, why not?
Author:  Jeff Highland [ Sat Jan 14, 2012 1:07 am ]
I would suggest pigment rather than dye.I have used the one designed to colour concrete.
Author:  Mike OMelia [ Sat Jan 14, 2012 1:51 am ]
I'm actually looking for a recipe. Actual resin name plus actual dye/pigment name.
I think I'm close based on what I've seen here
Author:  sumo [ Sat Jan 14, 2012 3:06 am ]
Have a look at the System Three products too. They sell a whole load of epoxies and hardeners. They also have a tinting epoxy paste. I personally have used their GelMagic product as an adhesive, but it could be used to fill engravings too. I also dyed it black with their paste and it is basically pure black now. After its cured, its really hard too. Not sure if that is a good thing for you since it will crack if you flex it too much. T88 is a bit more flexible. I'm not sure you would need a structural epoxy though for engravings. Just get any quality epoxy and add some lamp black or something to it. It should go black with only a small amount.
Author:  Rod True [ Sat Jan 14, 2012 3:12 am ]
Have you considered the engraving filler that Stew Mac sells? It's made by Grit Laskin.
Author:  B. Howard [ Sat Jan 14, 2012 8:20 am ]
I asked Petros about this at Woodstock this year, he uses epoxy with black tempera for his purflex. Did not say which epoxy though I'm sure he would answer a direct question via e-mail. I like Sytem 3's SB112 myself for it's clarity.
Author:  Ken C [ Sat Jan 14, 2012 11:03 pm ]
Mike, my typical approach is to mix Mohawk black powder stain with epoxy. A little of that powder can make epoxy coal black. I use it all the time with inlays.
Ken
Author:  blafleur [ Sun Jan 15, 2012 9:00 am ]
I've had good luck with Transtint black with System 3 epoxy. But a word of caution, don't use metallic powders with it, ones I've tried turned green. Rep at the company said it was because of caustic ingredients in the epoxy.
Author:  Shaw [ Mon Jan 16, 2012 2:27 am ]
Stew mac sells pigments for coloring epoxy for inlaying....Mike
http://www.stewmac.com/shop/Inlay,_pear ... 3&xsr=3484
Author:  Ron Belanger [ Mon Jan 16, 2012 11:21 am ]
Mohawk also makes an excellent line of colored pigments. I have used the black and brown for inlay. Heard about it from Dave Nichol at an ASIA inlay seminar.
Author:  Mike OMelia [ Tue Jan 17, 2012 11:52 pm ]
Thanks all, I'm going with the furniture powders & epoxy.
Author:  truckjohn [ Wed Jan 18, 2012 8:51 am ]
Product wise - the jar of pre-mixed black pigment I have says "System 3 Epoxy Pigment, Black".. Works real good in epoxy.. Takes one little blob on the end of a toothpick to dye about 1-oz of epoxy pitch black.
If you want something cheap that's super, perfect pitch black - it's hard to beat Lamp black... Available in most craft stores.... It's a fancy name for carbon black.... You could also make some yourself with a piece of lump charcoal and a mortar and pestle...
Just watch out - it's a powder and it gets all over everything! Literally... You won't know it's on your hands till you pick up something and leave black fingerprints....
Anyway, the upside is that it takes very little to perfectly dye stuff black... and it works with most anything... You can mix it into white glue or superglue if you are so inclined...
And.. It's more or less chemically stable - so it won't cause weird problems... Very likely the "Epoxy pigment, Black" is just mineral oil mixed with lamp black (THat's how we dyed all flavors of plastics black)... but it doesn't say... so I don't officially know...
Author:  John Coloccia [ Wed Jan 18, 2012 9:26 am ]
I use transtint in epoxy too for other colors, though you won't really get an opaque color. Why not just buy black epoxy?
Author:  John Shannon [ Wed Jan 18, 2012 3:03 pm ]
I've used SM's black epoxy for ebony headplate and fretboard inlays and it's worked great for me. Undetectable under finish in my experience.
Author:  Mike OMelia [ Sun Feb 05, 2012 10:20 pm ]
I bought several of the furniture powders (Behlen) and they worked awesome with epoxy and CA! Inlay gaps were flawlessly filled with CA and black powder. The stuff is really black, no graying with CA. Logo inlay with black powder and epoxy was perfect.
Thanks!
Author:  Tai Fu [ Sun Feb 05, 2012 11:35 pm ]
I use this epoxy that I get from a local chemical supply store. I don't know who made it but it sure smells like system three... it's a 3:1 mix.
