v-joint tutorial http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=33806 |
Author: | adamscottv [ Fri Oct 07, 2011 3:45 pm ] |
Post subject: | v-joint tutorial |
I found a reference to this tutorial by Joshua French, but now I see that all the images are gone: viewtopic.php?f=10102&t=10511 Does anyone know if the images are available somewhere? Has anyone archived the tutorial? Thanks! |
Author: | Michael.N. [ Fri Oct 07, 2011 4:31 pm ] |
Post subject: | Re: v-joint tutorial |
There is a Youtube video by David Schramm that gives some pointers to doing the V joint. I think he uses the Fussen joint, what some people refer to as the Hauser V. In reality that joint dates long before Hauser. There are a number of variations. I'm guessing that the J.French one was the through V - the type that Romanillos employed. Making accurate templates helps enormously, as does seriously sharp chisels. The best advice though is to get some scrap wood and do a couple of trials, just to get the feel. ![]() |
Author: | Markus Schmid [ Fri Oct 07, 2011 4:34 pm ] |
adamscottv wrote: Does anyone know if the images are available somewhere? Has anyone archived the tutorial? Try to combine with these pictures. ![]() |
Author: | Rod True [ Fri Oct 07, 2011 6:00 pm ] |
Welcome to the forum. Here's a few links for you to check out, hope they help. viewtopic.php?f=10101&t=28080&start=0&st=0&sk=t&sd=a&hilit=joint viewtopic.php?f=10101&t=26944&start=0&st=0&sk=t&sd=a&hilit=joint |
Author: | Arnt Rian [ Fri Oct 07, 2011 6:14 pm ] |
There are some pictures of my method in the beginning of this thread http://www.mimf.com/cgi-bin/WebX?14@121.eoxqav0dJgJ.2@.2cb6eac1/0 |
Author: | WaddyThomson [ Fri Oct 07, 2011 7:40 pm ] |
I did a tutorial over at Luthier Com using Joshua's procedure of hand cutting the joint. Here is a link. I had a few more pictures than Joshua did in his tutorial here. http://luthiercom.org/phpbb3/viewtopic. ... 513d2407b1 |
Author: | StevenWheeler [ Fri Oct 07, 2011 8:17 pm ] |
Here's another take on the joint. http://luthiersforum.com/forum/viewtopic.php?f=10117&t=21868 |
