Bending Ribbon Figure Mahogany again http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=33610 |
Author: | ChuckB [ Thu Sep 22, 2011 11:25 am ] |
Post subject: | Bending Ribbon Figure Mahogany again |
I am having difficulties with rippling while bending ribbon figured mahogany. I was able to get 8 b&s sets from a nicely quartered piece. I am down to 6 now, hope to get something out of this wood. My rippling is around .040" on sides that are .090" thick. I bent it like I have before with plain mahogany, 280 degrees and light spritz of water. The sides look like what I found in the archives in this thread viewtopic.php?f=10102&t=5828&hilit=bending+ribbon+mahogany. It stated bending at 300 degrees, just wondering if it worked? I thought I'd check before wasting anymore sides. Thanks, Chuck |
Author: | David Newton [ Thu Sep 22, 2011 6:10 pm ] |
Post subject: | Re: Bending Ribbon Figure Mahogany again |
What's the question? .090" is pretty thick for sides. |
Author: | ChuckB [ Thu Sep 22, 2011 6:14 pm ] |
The question is, did increasing the bending temp to 300 degrees eliminate the rippling? Dave, what thickness do you recommend? Chuck |
Author: | ChuckB [ Thu Sep 22, 2011 7:52 pm ] |
Thanks Filippo, I'll try .080 and veneer softner, and 300 degrees. I've had other mahogany that bent easily (with some spring back), but this stuff is a totally different animal trying to control the ripples that follow the ribbon figure. Chuck |
Author: | alan stassforth [ Thu Sep 22, 2011 9:03 pm ] |
I bent some African Mahogany not too long ago. It had ribbon grain, sized to .095". Hardest wood I've bent yet. Just wanted to spring back. I use .095" because it's for weiss jobs, and I think the sides need the thickness for strength. I just kept at it. |
Author: | Alain Desforges [ Fri Sep 23, 2011 9:50 am ] |
You need the bender of death! And I'm no expert, but have you considered bending dry? |
Author: | ChuckB [ Fri Sep 23, 2011 12:09 pm ] |
Alain, I did bend one side dry, no difference, ripples along ribbon figure. Chuck |
Author: | Ti-Roux [ Fri Sep 23, 2011 11:04 pm ] |
alan stassforth wrote: I bent some African Mahogany not too long ago. It had ribbon grain, sized to .095". Hardest wood I've bent yet. Just wanted to spring back. I use .095" because it's for weiss jobs, and I think the sides need the thickness for strength. I just kept at it. Have you ever consired laminated sides for your weiss's? I just did on my 2nd guitar, and really, it's easier that it seems. Instead of bending a .090'' Koa side, I bent a .070 Koa side and a .040 Spanish side. Then I get a .110 side, at the perfect shape, absolutely no spring back, no warp, no flat-spot. And don't need side braces. |
Author: | alan stassforth [ Sat Sep 24, 2011 6:17 pm ] |
Thanks for that idea Francis. Maybe I'll give that a go. |
Author: | Ti-Roux [ Sat Sep 24, 2011 11:24 pm ] |
alan stassforth wrote: Thanks for that idea Francis. Maybe I'll give that a go. It also gives more stabilty to the structure without adding much weight. That results in less energy loss, then in considerable gain in volume and projection. Let us know if you try it! ![]() |
