wax finish for guitars http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=33264 |
Author: | Tai Fu [ Sat Aug 20, 2011 11:00 am ] |
Post subject: | wax finish for guitars |
Has anyone sold a guitar with a wax only finish? I mean where you simply rub beeswax onto the guitar, then buff it with a cloth wheel like you would finish a wood turning or ebony items. It seems to be one of the simplest finish out there and feels great too, not to mention it's easy to repair. I wonder how well it protects the wood from warping due to excess moisture...? |
Author: | runamuck [ Sat Aug 20, 2011 1:07 pm ] |
Post subject: | Re: wax finish for guitars |
I've never finished a guitar with wax but I've tried wax-only on furniture. It doesn't last long; wax not only has very little protective power but it oxidizes fairly quickly and eventually disappears. It'll slow down humidity changes but not much. With as much as a guitar is handled I say forget it. |
Author: | Alex Kleon [ Sat Aug 20, 2011 1:10 pm ] |
Beeswax alone would be much too soft, and would smear easily. You would need to add carnuba wax to the beeswax to make it harder. As a finish for a guitar, I don't know, but once you put wax on wood you wouldn't be able to put any other finish on it. Even sanding would likely leave the wood contaminated. I don't think wax alone would protect against perspiration and oils from your hands let alone moisture in the air. Alex |
Author: | CharlieT [ Sat Aug 20, 2011 5:29 pm ] |
I have a hunch that wax would not do good things for the tone of a guitar. |
Author: | Laurent Brondel [ Mon Aug 22, 2011 6:50 am ] |
Wax was a traditional finish for lute tops, so it can't be bad for tone⦠It gives little protection, and spruce will quickly become dirty from contact with skin and clothes. It may be desirable, but so far the acoustic guitar market has decided otherwise. |
Author: | Carlos Juan Busquiel [ Tue Aug 23, 2011 1:36 pm ] |
I have applied wax for a satin finish, but I first french-polish the guitar. I mean, I varnish the guitar as I normally do with shellac. After that I apply wax with the help of very fine steel wool, killing the gloss and obtaining a satin finish. |
Author: | Rod True [ Tue Aug 23, 2011 4:33 pm ] |
CAJUAN wrote: I have applied wax for a satin finish, but I first french-polish the guitar. I mean, I varnish the guitar as I normally do with shellac. After that I apply wax with the help of very fine steel wool, killing the gloss and obtaining a satin finish. Yes, but that is not a wax finish, it's just a lubricant for the fine steel wool. I've done the same over nitro. |
