http://www.luthiersforum.com/forum/
Show me your florentine bending jig setup please
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=33051
Author:  Paul Burner [ Mon Aug 01, 2011 9:10 am ]
Post subject:  Show me your florentine bending jig setup please
I am looking for ideas on a jig I can build to bend my florentine cutaways. I made a setup for my fox-style bender but don't like the way it is working.
Long ago I had a photo of a setup Kevin Ryan uses - and it looked pretty straight forward. Might have to email him again to see if he still has that photo....
But I want to know what YOU do for your florentines. I'm really bad with a bending iron - and want something that gives me repeatable results.
Photos greatly appreciated!
Author:  Rod True [ Mon Aug 01, 2011 10:00 am ]
Post subject:  Re: Show me your florentine bending jig setup please
I use to have one like Jim Olson's, but I wasn't happy with it so I'm remaking it. I've done the last several by hand though and that was easy.
Author:  Paul Burner [ Mon Aug 01, 2011 10:07 am ]
"I'm really bad with a bending iron..."
I just don't have the "feel" for it.
Author:  Paul Burner [ Mon Aug 01, 2011 11:05 am ]
Todd,
I actually made something similar to this - and used it on 3 guitars. Found out that my male/female set wasn't the right shape as it didn't take into account the thickness of the slats/blanket. Since I need to redo the entire thing I figured I would look at other options.
I'm not finding the tutorial you mentioned - can you direct me to it?
Todd Stock wrote:
I've bent by hand and done a jig like Olson's, but the easier was a male/female set of cauls for the Fox...painless and quick...once the forms were done. If you standardize on a particular shape, it's worth the time to make up the forms. I use this one for my SJs...on the fourth use, so at least for folks using figured mahogany, curly anigre, or other fun-to-bend woods, a good investment. Both the bending caul and form made exactly as shown in the tutorial.
Author:  TonyKarol [ Mon Aug 01, 2011 3:45 pm ]
here is mine .. never fails .... the springs load the teniosn into the slat, and away you go. I let it heat on full (2.5 watt blanket) for about 2 minutes, then do the bend in about 30-45 seconds total ... its way easy to make, no mating forms !!! only the inside of the curve is required, I have mine overbend a touch..
Author:  dberkowitz [ Wed Aug 03, 2011 10:52 am ]
Anyone have a good method for gluing the corner block on a florentine? I made an outside fixture with the block being forced in against it, and it works ok. My main problem is that getting the sides to align properly, i.e. getting things square, when gluing is tough.
Author:  Rod True [ Wed Aug 03, 2011 11:24 am ]
David, I've made an outside mold too for gluing the corner block ala Olson Style.
I've started now by taping the sides at the point (sort of like doing binding) during the dry fit. I leave the top edge of the side flat for alignment purposes and just do the tape up on my table saw top to ensure the sides are square. Use as much tape as you like to get it all lined up and tight, then put it in the outside mold, glue on the inside block then clamp up. I've clamped in the go-bar deck as well as with 4" F-clamps and I think I like the F-clamps best. The tape of course will help pull the sides tight as it stretches.
Author:  dberkowitz [ Wed Aug 03, 2011 11:51 am ]
Rod, I have a similar setup and concur on the clamps, but nonetheless, the block and pieces do slide as you press that puppy home.
Author:  Paul Burner [ Wed Aug 03, 2011 5:20 pm ]
Todd Stock wrote:
Sounds like you need to remake either the caul or the form...just allow for side thickness plus the thickness of foil, paper, slats, blanket, etc.
Todd, can I call you to discuss some details on your setup please? If so, email me at paul at burnerguitars dot com
thanks
Author:  Paul Burner [ Wed Aug 03, 2011 6:08 pm ]
Tony,
On your setup are you putting the wood directly against the pattern - and then heating blanket then slat?
Paul
