Where to put the battery pack http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=32621 |
Author: | Neil Gardiner [ Mon Jun 20, 2011 2:50 pm ] |
Post subject: | Where to put the battery pack |
I'm installing a pickup and the instructions say to put the battery pack somewhere flat and out of sight. Where do you guys usually put it? It's a Shatten pickup I'm installing. Thanks Neil |
Author: | TonyKarol [ Mon Jun 20, 2011 3:00 pm ] |
Post subject: | Re: Where to put the battery pack |
bass side of the neck block, attached on the guitar's side, when using the self adhesive/velcro type |
Author: | woody b [ Mon Jun 20, 2011 4:28 pm ] |
I usually put them underneath the fingerboard. You can reach inside through the soundhole with a couple fingers and pull the battery out to change without even loosening the strings. |
Author: | Colin North [ Tue Jun 21, 2011 5:51 am ] |
Battery box makes a neat and easy to change solution too, without having to loosen strings. Mine is near the tail block. |
Author: | Mike Collins [ Thu Jun 23, 2011 12:48 pm ] |
I do the same as Colin. I get them from Stew-Mac. Mc |
Author: | Darryl Young [ Thu Jun 23, 2011 12:56 pm ] |
I was curious if anyone maounted the battery pack near the tail block to help balance a neck heavy guitar. Maybe the batteries are light enough that this isn't an issue, not sure. |
Author: | Colin North [ Thu Jun 23, 2011 5:48 pm ] |
Darryl Young wrote: I was curious if anyone maounted the battery pack near the tail block to help balance a neck heavy guitar. Maybe the batteries are light enough that this isn't an issue, not sure. Every little bit helps.... |
