http://www.luthiersforum.com/forum/
automotive finishes for acoustic guitars
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=32609
Author:  mugz [ Sun Jun 19, 2011 10:41 am ]
Post subject:  automotive finishes for acoustic guitars
Has anyone used automotive finish before. Im looking for a faster cure time and less shrinkage than traditional laquer. Any ideas ?
Author:  johnparchem [ Sun Jun 19, 2011 11:21 am ]
Post subject:  Re: automotive finishes for acoustic guitars
you can use a UV cured finish.
viewtopic.php?f=10101&t=31371&hilit=CureUV
http://cureuv.com/uv-guitar-finishing.html
Author:  Chris Pile [ Sun Jun 19, 2011 11:41 am ]
I used automotive lacquer for nearly all my finishes.
Author:  ChuckB [ Sun Jun 19, 2011 11:50 am ]
I have used catalyzed urethane, which is the clear coat part of the base coat clear coat auto finish. It does shrink slightly, so I applied three coats on day 1, level sand the next day and apply another two coats. Wait two days level sand again and buff. Total finish thickness about .005". It takes more time and effort to buff since it is a harder finsh. Looks like nitro laquer, just does't have the amber tint and not as easy to touch up. That said, I still use nitro as my standard finish.
Chuck
Author:  woody b [ Sun Jun 19, 2011 7:21 pm ]
I know of several builders (some which I respect alot) who use automotive finishes. I haven't used automotive finishes (on anything except automobiles) so I won't comment further.
Author:  Ken Franklin [ Mon Jun 20, 2011 1:22 am ]
I use Dupont Chroma Clear for most of my guitars. It is easy to apply and buffs to a nice high gloss but it does shrink some. So I have gotten used to spraying two base coats over well-cured CA pore fill and waiting about a week or so before I level and spray the two final coats. Then I can sand and buff the next day which is preferable because it makes sanding and buffing harder if I wait longer.
Author:  Lindamon [ Mon Jun 20, 2011 6:51 am ]
I have used automotive finishes on two aircraft I painted. Be aware some can be quite toxic (isocyanates). Much worse than nitro on your health. I used a full suit and breathing turbine when I sprayed it.
