http://www.luthiersforum.com/forum/
Western red cedar top bracing?
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=32586
Author:  Scott A [ Thu Jun 16, 2011 8:18 pm ]
Post subject:  Western red cedar top bracing?
Does anyone use Western red cedar for bracing the soundboard?
Author:  Daniel Minard [ Thu Jun 16, 2011 9:58 pm ]
Post subject:  Re: Western red cedar top bracing?
I love red cedar for many reasons, but wouldn't use it for any bracing job except perhaps fan bracing on a classical guitar. It just splits too readily.
I read a post by Mario Proulx a couple of years ago & he said he has used it successfully for steel string guitar bracing.
Author:  Laurent Brondel [ Fri Jun 17, 2011 7:30 am ]
Too weak, prone to splitting too easily in case of shock or movement. It would work if used as laminations Larson style, but it's not like there's an availability problem on spruce.
Author:  ernie [ Fri Jun 17, 2011 8:23 am ]
Western red cedar top would do better with spruce bracing, as the others mentioned for a host of reasons. Because WRC is lighter than a spruce top, one correspondingly needs to add at least 1 extra mm of height to the bracing. I have a lot of WRC it also varies widely in density, so you might want to adjust your fan/transverse bracing to get at least 3 different tones when you are completing the final ramping of your transverse an fan braces , top upper bout, center below soundhole and lower bout.
Author:  jfmckenna [ Fri Jun 17, 2011 11:50 am ]
I build my Torres braces classical's with the three center fans spruce and the outer fans WRC. There's an idea behind it, maybe its a dumb idea laughing6-hehe but so far no problems and I've got one going on 15 years old.
