It is currently Mon May 25, 2026 4:40 am
PostPosted: Mon Jun 13, 2011 9:01 pm
Last Name: coloccia
Country: States
How do you guys deal with different nut widths for your headstock templates? New template for each nut width? Construct it to the largest width and blend it by hand? Half templates and simply line up the outer edges with the edge of the fingerboard?
PostPosted: Mon Jun 13, 2011 10:02 pm
Mine is oversized at the nut and gets blended in during neck carving...
PostPosted: Mon Jun 13, 2011 10:09 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I blend that kind of stuff by hand anyhow, so not a big deal for me.
Chris.
PostPosted: Mon Jun 13, 2011 10:19 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I use a cad program..Delta cad...and make half templates which can be used to make one piece templates ..in fact I use the cad program to draw out several things..such as heel templates , brace templates, string layouts on nuts, bridge templates .etc and attach with low tack spray adhesive. since I dont make that many guitars , I can make changes easily. In fact on one of my current builds I didn't like the way the headstock turned out so I redrew it making adjustments to fit the material, made a half template then attached it with two sided tape and rerouted , worked perfect..
MK5acoustics.com
PostPosted: Mon Jun 13, 2011 11:06 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
The templates I use are sized a little bigger at the nut than my widest neck. Once the fingerboard is glued on, it's a simple job fairing in the last inch or so with a chisel.
PostPosted: Tue Jun 14, 2011 7:05 am
Last Name: coloccia
Country: States
Yes, okay...mine is also oversized at the moment and I just simply blend it when carving the neck. It's always a little stressful for me because early on I made some funny looking "blends" that didn't really turn out all that well...I haven't done that in a while but it still makes me a little nervous :) Well thanks for the feedback...it makes me feel better that I'm doing it conventionally.
PostPosted: Tue Jun 14, 2011 11:14 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I blend by hand, as I finish shaping the transition from the neck
to the peghead.
Gene
