It is currently Tue May 26, 2026 2:11 am
 Post subject: HF Pencil Grinder
PostPosted: Sat Jun 11, 2011 11:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I am not sure if they always had these, but I noticed them the other day. Y'all seen this? http://www.harborfreight.com/catalogsea ... il+grinder
I bought one for about $22. And it works great!!
 Post subject: Re: HF Pencil Grinder
PostPosted: Sun Jun 12, 2011 12:26 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Router base? I'd be interested in seeing that. I intend to use it (them) in duplicators and pantograph machines. You could by 5 of these for one Souix. (sp?)
PostPosted: Sun Jun 12, 2011 9:19 am
I had one and it crapped out out after a bit so I took it back. They are hit and miss. I just don't have the time to waste running back and forth exchanging them. Some have more runout then others and will spit out oil.
Mine also vibrated enough to loosen up the collet.
Good luck with yours, seems you found a good one(for now). Hope it last.
Here's a pic of mine in the ellipsograph . You can use it as a model for a plunge base. Just make the base a little larger.
PostPosted: Sun Jun 12, 2011 3:45 pm
I havn't use them on a few years. The run out on the shaft was often pretty sever . I found another brand.but this tool is can be very useful. The higher speeds that they run at will make a smoother cut and you will see they are lighter .
Users browsing this forum: meddlingfool and 59 guests
