It is currently Tue May 26, 2026 3:36 am
 Post subject: Picked up at yard sale.
PostPosted: Sat Jun 11, 2011 8:13 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I picked up this 1980s guitar at a yard sale this morning for $20 figuring I could always use the case and tuners for that amount. It is very clean but for the fact it seems to have sunk just a little where the fretboard meets the rosette. I have been building like mad but have not done any repairs. I have no idea how to get the neck off without trashing it. I'm wondering There is a block of mahogany the trussrod runs thru below the fretboard. I'm wondering if I could lift the area just ahead of the rosette and glue a block from there to the endblock as a fix. The guitar looks and sounds good but as you can see from the photos the neck angle is about 1/4 inch off.
Any ideas.
http://goatrockukulele.com
PostPosted: Sat Jun 11, 2011 9:25 pm
I have repaired a boat load of these back in the late 70's and 80's. Usually the neck blocks had come unglued from the top, sides, & back.
Rather than add some block or other, figure out what has shifted and repair it back original.
I know the guitar is probably not worth all the work, but if you want to ever do repairs for $$, you should learn how to do it right.
PostPosted: Sat Jun 11, 2011 11:30 pm
They were famous for that. Fixed a buttload of them myself.
PostPosted: Sun Jun 12, 2011 11:37 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
You might be surprised at how relatively easy it is to remove the neck and re set it. A good playing guitar with a few minor blemishes is always worth more than one that doesn't play. I re set the neck on a harmony twelve string and it wasn't bad at all loosening up the glue joint using heat and steam. Removing it is the least of your worries I would guess.
Users browsing this forum: No registered users and 61 guests
