It is currently Sun May 03, 2026 4:08 pm
PostPosted: Thu Jun 02, 2011 11:15 am
Poll: Bracewood -do you saw or split?
PostPosted: Thu Jun 02, 2011 11:16 am
First name: Marcus
Last Name: Bailie
City: Kirkland
Saw. I'm too lazy to split.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Thu Jun 02, 2011 11:22 am
Nice to see you here Chis.
Split, of course, then saw.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Thu Jun 02, 2011 11:27 am
Definitely split, then saw. For those that don't, look at the thread on x brace caps.
Chuck
PostPosted: Thu Jun 02, 2011 11:28 am
City: Jacksonville
Split
PostPosted: Thu Jun 02, 2011 11:30 am
Hi Chris. 90% of what I get comes from split billets so there's almost no runout to begin with. I get one edge parallel to the grain lines and saw from there.
http://www.chassonguitars.com
PostPosted: Thu Jun 02, 2011 11:38 am
All my stock comes from split billets. I straighten the edge if need be and saw from there.
PostPosted: Thu Jun 02, 2011 11:44 am
saw, using a split face as a reference,
PostPosted: Thu Jun 02, 2011 11:47 am
First name: Tom
Last Name: West
State: Nova Scotia
Chris: Looks like the consensus is YES. Split and saw,thats also how I do it. If you are wondering if sawn billits are the way to go for sale at LMI, I would really suggest that you not eliminate the split ones. Have tried sawn blanks from a couple of sources and now I will not buy because I find they are a waste both of time and wood. Just my experience ,others may suggest otherwise.
Tom
PostPosted: Thu Jun 02, 2011 12:29 pm
My brace wood from High Mountain Tonewood usually comes perfectly quartered, so no need to split.
PostPosted: Thu Jun 02, 2011 12:43 pm
Last Name: Hodge
Another one here for split, then saw. So I guess the answer is, both!
Bill Hodge
PostPosted: Thu Jun 02, 2011 1:04 pm
Yep, split then saw!
Joe
PostPosted: Thu Jun 02, 2011 1:29 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Wow, I feel like a tool. I guess I'll start splitting :D
-Marcus
Instagram | YouTube
PostPosted: Thu Jun 02, 2011 1:41 pm
First name: Darryl
Last Name: Young
State: AR
After my first experience cutting brace wood which was Sitka with runout, I split the billet down the middle then resaw each half from the split side.......then final touch up on the drum sander.
PostPosted: Thu Jun 02, 2011 1:55 pm
+1 split, to get a reference surface, then saw.
PostPosted: Thu Jun 02, 2011 3:25 pm
Last Name: Kincheloe
Split and plane for me. But that's cause I don't use all them hungry power saws, and hand sawing a straight line is more tricky than whacking it with a chisel again.
PostPosted: Thu Jun 02, 2011 4:50 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Split from billets, then saw...
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Thu Jun 02, 2011 7:04 pm
Yep, split and saw here too.
Gwaltney Guitars
PostPosted: Fri Jun 03, 2011 2:18 am
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
The sticks I bought from LMI I just sawed because they were square and quartered. Nice wood on LMI's part; but expensive. Now I get my bracing from another source, for ALOT less, but its more work to get it square. LMI should offer chunks of bracewood with no runout. It's light, it should'nt cost much to ship. As long as 1 side is flat, Most luthiers can work with it. I'm sure theres TONS of bracewood that sits in the forest floor and rots. There are luthiers around the world that are starving for wood for musical instruments that can't affor the good stuff. Chris, I work for the USPS, and I know you can ship dry chunks of spruce around for not as much as u think, cheaper than ups, and fedex. LMI has good wood.
Jason Moe
LaCrosse WI 54601
PostPosted: Fri Jun 03, 2011 4:53 am
split / saw / shape I had to add something LOL
PostPosted: Fri Jun 03, 2011 5:59 am
I use brace wood that is left over from high end violin makers billets, these were split first before the violin wedges were cut, so that the faces I have are ready to take straight to the band saw. But I guess that still counts as split, then saw!
PostPosted: Fri Jun 03, 2011 6:53 am
Country: Romania
If you split a rather large billet down the middle it is not a guarantee there won't be any runout an inch or two farther away. Most trees have a wavy inconsistent growth, to a certain extent. As a result I make all braces by splitting as close as possible to the final dimension then truing with a plane. It's more waste and work though.
Build log
PostPosted: Fri Jun 03, 2011 8:31 am
First name: Corky
Last Name: Long
City: Mount Kisco
Me too.
PostPosted: Fri Jun 03, 2011 9:05 am
I just buy mine from Shane, and it's nearly perfectly quartered, and with minimal runout, so I can just saw it.
PostPosted: Fri Jun 03, 2011 9:10 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Split- saw.
I end up with some kindling.
Users browsing this forum: No registered users and 200 guests
