Smaller than Martin D5 http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=32176 |
Author: | herry tze [ Thu May 12, 2011 11:02 am ] |
Post subject: | Smaller than Martin D5 |
Hai, Luthiers,... my question is any other smaller model than Martin D5? (classical) with 6 nylon strings? And where can I get the Plan... thank's a lot... ![]() |
Author: | Quine [ Fri May 13, 2011 10:33 am ] |
Post subject: | Re: Smaller than Martin D5 |
Maybe the MIMF plans would work for you...The plans for the "small guitar/baritone uke" https://secure.mimf.com/order.htm I'm not sure how it compares to a Martin Size 5 but it looks pretty small |
Author: | Pat Foster [ Fri May 13, 2011 10:38 am ] |
Quine wrote: Maybe the MIMF plans would work for you...The plans for the "small guitar/baritone uke" https://secure.mimf.com/order.htm I'm not sure how it compares to a Martin Size 5 but it looks pretty small It's considerably smaller than the Martin Size 5 Terz. |
Author: | Pat Foster [ Fri May 13, 2011 3:20 pm ] |
Yes, puzzling. D5 classical? Herry, can you clarify? Pat |
Author: | bluescreek [ Sat May 14, 2011 8:52 pm ] |
I can find no mention if a CF Martin D5 There is a D1 The size 5 is called a parlor , terz and a 1/2 size dred . |
Author: | herry tze [ Sun May 15, 2011 4:25 am ] |
I'm sorry about that false style of Martin D5, this the true syle, Summer 2009: A Martin-style Size 5 Guitar!!! I've decided to build a cute little Martin-style Size 5 guitar this summer. This will be the fourth one I've built. The others belong to friends and family — this one's for me! . I've known from Kathy Matsu shita..... aah here the spec from Kathy's block: The only other resource for the Size 5 style I've found since is Scott Antes's plan for what he calls a "3/4 Size" guitar, available at Luthiers Mercantile. It's a full blueprint, with specifications for every aspect of this guitar style. THE SIZE 5's DIMENSIONS (approximate): Body length = 16", Upper bout = 8-1/4", Lower bout = 11-1/4", Waist = 7", Body depth at tail = 3-7/8", Body depth at neck = 3-1/8", Scale length = 21.3" (I cut off a pre-slotted, 16" radiused 25.34" scale fingerboard at the 3rd fret.), 12th fret at body. thank's |
