http://www.luthiersforum.com/forum/
Further Thicknessing A Top After the Soundhole Is Cut
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=31921
Author:  Ron M. [ Thu Apr 21, 2011 8:52 am ]
Post subject:  Further Thicknessing A Top After the Soundhole Is Cut
I realized that I need to remove close to another millimeter after the soundhole was cut. Should I be cautious when further thicknessing after the sound hole has already been cut out? I still have the center circle cut-off that I can fit back in when re-thicknessing.
Ron M.
Author:  Tom West [ Thu Apr 21, 2011 9:40 am ]
Post subject:  Re: Further Thicknessing A Top After the Soundhole Is Cut
Rosette installed....???
Author:  John Mayes [ Thu Apr 21, 2011 11:46 am ]
On a drum sander go right ahead. You won;t cause any damage to the cut out soundhole area.
Author:  Tom West [ Thu Apr 21, 2011 2:34 pm ]
Ron: Suggest you sand the inside surface if you are removing .040".
Tom
Author:  Ron M. [ Thu Apr 21, 2011 3:16 pm ]
Hi Tom
yes, It's installed. Thanks
Hi John,
thanks for help.
Author:  Ken Franklin [ Fri Apr 22, 2011 12:12 am ]
Make sure that you have enough wood under your rosette if you are only thicknessing the back.
