OLF Orchestra model end blocks http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=31587 |
Author: | cgal_1 [ Thu Mar 24, 2011 6:57 am ] |
Post subject: | OLF Orchestra model end blocks |
Is it better to rout the neck block before fitting it or after? If after, then should I wait until the top and back are attached or do it after the kerfing is done? |
Author: | gozierdt [ Thu Mar 24, 2011 11:15 am ] |
Post subject: | Re: OLF Orchestra model end blocks |
+1 for Todd's answer. There are a lot of chances for mis-alignment if you route the raw block. I've never had a problem routing after the box is closed. If you look at Robbie O'brian's toot on YouTube you'll get a good idea how easy it's done. Luthier Tips du Jour - Bolt on Mortise and Tenon Neck Joint http://www.youtube.com/watch?v=yzlZvDyKnPI |
