http://www.luthiersforum.com/forum/
Intonation question.
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=30403
Author:  jpeiffer [ Mon Dec 20, 2010 7:19 pm ]
Post subject:  Intonation question.
This is on and older Gretsch electric (1965 Corvette). I had trouble setting intonation. After a couple of attempts I put a capo on the 3rd frett, tuned then set intonation at 12th frett. Removing the capo all strings sound low. I put a piece of wire about 1/16" from the nut and it played in tune. As if the fingerboard was too long??? No sign of a neck reset (it is a set neck). Any thoughts?
Author:  bluescreek [ Mon Dec 20, 2010 7:27 pm ]
Post subject:  Re: Intonation question.
can you post pics ? A way to see if that is the case is to cape the 1st fret tune and check intonation on the 13th fret . If that is the case the nut is out of postion .
