http://www.luthiersforum.com/forum/
Sanding blocks and pads
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=30340
Author:  TonyFrancis [ Thu Dec 16, 2010 4:17 am ]
Post subject:  Sanding blocks and pads
Author:  Kim [ Thu Dec 16, 2010 4:31 am ]
Post subject:  Re: Sanding blocks and pads
Festo make pads which vary in density, hard medium and soft.
Author:  bluescreek [ Thu Dec 16, 2010 6:50 am ]
I have a collection of sanding blocks and use anything from Aluminum to foam rubber . FRETS is a reference on my puter to. A great service to anyone that like guitars. There isn't more I can ad. I use PSA sandpaper for many blocks . I love the stuff from 60 to 120 grit
Author:  unkabob [ Thu Dec 16, 2010 10:59 am ]
I keep a set of those cheap black rubber sanding blocks with varying grits from 120 to 320. I use spray adhesive to hold the paper tight. Sand the bottom of each block flat before you start as many have contures or mold marks.
Above 320 grit I usually use fingers.
Bob :ugeek:
Author:  Barry Daniels [ Thu Dec 16, 2010 11:09 am ]
Not many truly flat surfaces on a guitar so hard blocks don't really make sense.
I use a Pink Pearl eraser, or a cork block used for waxing cross country skis.
Author:  ChuckG [ Thu Dec 16, 2010 12:50 pm ]
I use UHMW plastic blocks for really getting a surface dead flat and felt blocks for everything else including wet sanding a finish. The UHMW is great for use with rolls of PSA sandpaper because the sticky glue is easy to clean off where that's not the case with wood.
Chuck
Author:  Pat Foster [ Thu Dec 16, 2010 1:09 pm ]
My Bosch ROS has pads of various densities. I use the hardest.
For hand sanding, I use 2" x 2" x 1/4" thick acrylic for pre-finish prep on the body, except the waist, and the front and back of the headstock. The same for leveling the finish. After the finish is level, I use the dense foam pad that comes with the Micro-Mesh kits. I find that the flatter everything is, the less sand-through I get, important to me since I brush on varnish.
Author:  truckjohn [ Sat Dec 18, 2010 3:20 pm ]
I use auto body shop sanding blocks - recommended by my nephew who does auto body work on the side....
Durablocks are the ones - they are some sort of medium/soft poly foam....
They made all the difference in my finish quality and speed....
