http://www.luthiersforum.com/forum/
Neck Angle - Final Check
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=30278
Author:  George L [ Fri Dec 10, 2010 6:11 pm ]
Post subject:  Neck Angle - Final Check
I'm about ready to start finishing the L-00 style model that I've been working on, but would like to check my neck angle measurements with the group here before doing so. Here's the story...
My fretboard has a maximum thickness of 9/32". With the neck bolted in position and a straightedge running down the center of the fretboard the point where the fretboard will intersect the front of the bridge is 11/32" above the soundboard. My bridge is 23/64" tall, so that puts my straightedge 1/64" below the height of my bridge. Once I put my frets in I'm thinking this will be just about perfect. Am I thinking correctly? Or should I finesse the neck angle so that my straightedge is just a touch higher?
One other element to the fit that I would like advice on is the fretboard extension. As it sits in the measurements above, there is a 1/64" gap between the fretboard extension and the soundboard. This closes readily with the slightest pressure and I can't see any hump when I do so. Again, my thinking is that this is okay and may actually help maintain a little fall away over the frets in that area. What's the consensus? Am I kooky? Or good to go?
Author:  meddlingfool [ Fri Dec 10, 2010 6:19 pm ]
Post subject:  Re: Neck Angle - Final Check
Sounds about right to me. But why not leave your tongue unglued til you string it up? Then you can make any adjustment before committing... Ah the beauty of a bolt on!
Author:  Terence Kennedy [ Fri Dec 10, 2010 7:49 pm ]
A lot depends on how much the guitar moves when strung up. I usually like to have the straight edge clear the bridge between 1/32 and 1/16 before fretting on mine. I've found that when you glue the fretboard extension to the top it stabilizes the neck movement a little so it may not be exactly as it was strung up with the extension unglued.
There's probably a case to be made for setting the neck with a surrogate bridge but not making the real one until the finish is on and the neck attached. You can support the headstock and add 5 or 6 lbs to each shoulder and get an idea how much movement you are really going to get
I've been using a bolted fretboard extension for several years and that pretty much solves the problem as you can adjust at any time.
Author:  woody b [ Fri Dec 10, 2010 8:25 pm ]
The top will rise some under string tension, especially if it's a lightly built responsive top. I set my unfretted FB plane .050" above the bridge.
Author:  George L [ Fri Dec 10, 2010 11:51 pm ]
Thanks for the responses. Good to know! I was never sure about measuring with frets in place or without. Now I know and will do a little finessing tomorrow before moving into the finishing phase.
I don't plan to glue the extension until later, but I like to have everything as close as possible before then. I find that the less I have to do after finishing the greater my chances of not scratching, dinging, gouging, scraping or generally messing things up.
Author:  bluescreek [ Sat Dec 11, 2010 6:40 am ]
I like to do 2 things when setting necks on a new guitar. First , with the fretboard off I like to see about 1/16 to 1/8 inch off the top at the saddle position . With the fretboard I want my straight edge to just clear the bridge. With the frets on I do want to see a 1/16 to 3/32 off the thickest part of the bridge.
In the end I want 1/2 inch string height in front of the bridge. I like about .150 saddle exposed so a .350 bridge and .150 saddle is .500 that is my target . Get it close and you will be fine. I don't like to be more than .180 on saddle height. I will work with a .410 thick bridge to start and once the neck is on the guitar I can do some final tweaking . Here is a link to the tweaking process. http://theunofficialmartinguitarforum.y ... pic/111531
Author:  TonyKarol [ Sat Dec 11, 2010 10:33 am ]
To replicate the fret hieght, use a couple of veneer shims to approx 40 thou .. this gives you a better idea where things lie. Fretted, I too like to see about 50-60 thou of gap to the bridge top
