| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Disassembling you guitar http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=30218 |
| Author: | mhammond [ Sun Dec 05, 2010 1:22 pm ] |
| Post subject: | Disassembling you guitar |
Good morning: Every once in awhile you have to remove a bridge or fretboard for whatever reason. Some people use irons, heat guns or heat blankets. I use halogen work lights, I find them to be easily controllable and fairly safe. This is how I do it..... The bridge on this parlour had to go for several reasons. Attachment: small 020.jpg A couple layers of paper towel for insulation. Attachment: small 021.jpg A layer of foil shiney side up. The halogen work lite from HD is just right. Within 9 minutes the surface temp of the bridge was 314 f. Careful!!! Attachment: small 023.jpg A judicious application of putty knife and it popped right off with NO finish damage. WOOHOO! Attachment: small 024.JPG A little clean up where necessary. Attachment: small 025.jpg Hopefully some of you will find this useful. Thanks for being here, Mikey |
| Author: | Bobby M [ Sun Dec 05, 2010 1:35 pm ] |
| Post subject: | Re: Disassembling you guitar |
Great idea! |
| Author: | CharlieT [ Sun Dec 05, 2010 2:20 pm ] |
Yep, great idea! Thanks for sharing, Michael. |
| Author: | Andy Birko [ Sun Dec 05, 2010 3:22 pm ] |
Coolness. As an aside, I used the guts to one of those lamps to make my pipe bender. |
| Author: | Lindamon [ Sun Dec 05, 2010 4:14 pm ] |
Very nice! What was the type of glue? Do you think that will work with a titebond glued bridge? |
| Author: | mhammond [ Sun Dec 05, 2010 4:24 pm ] |
I believe that with the application of heat almost all of the common glues will eventually give up. However, having said that, someone will find something that won't oblige. Mike |
| Author: | RustySP [ Sun Dec 05, 2010 4:55 pm ] |
Mike, with the bridge plate and X-brace just on the other side, did you notice any softening of their glue joints? |
| Author: | bluescreek [ Sun Dec 05, 2010 9:17 pm ] |
A heat blanket can be controlled so you can dial in a heat . light is radiant and you can't control the temp other than time. I pull bridges cold with a chisel . You can use anything that makes heat to get a glue joint to fail . I prefer contact heaters , for control and less damage . You can fry finishes with lights if you are not careful. There are so many ways to do things , there is no one perfect way to do anything. If it works , that is all that matters . |
| Author: | guitarjtb [ Sun Dec 05, 2010 9:25 pm ] |
