It is currently Fri May 08, 2026 2:33 am
 Post subject: Disassembling you guitar
PostPosted: Sun Dec 05, 2010 1:22 pm
Last Name: Hammond
Good morning:
Every once in awhile you have to remove a bridge or fretboard for whatever reason. Some people use irons, heat guns or heat blankets. I use halogen work lights, I find them to be easily controllable and fairly safe. This is how I do it.....
The bridge on this parlour had to go for several reasons. :roll:
A couple layers of paper towel for insulation.
A layer of foil shiney side up. The halogen work lite from HD is just right. Within 9 minutes the surface temp of the bridge was 314 f. Careful!!!
A judicious application of putty knife and it popped right off with NO finish damage. WOOHOO!
A little clean up where necessary.
Hopefully some of you will find this useful.
Thanks for being here,
Mikey
The Biggest Little City, Nevada
www.hammondguitars.com
I love building guitars!
PostPosted: Sun Dec 05, 2010 1:35 pm
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
Great idea!
Bobby Masten
PostPosted: Sun Dec 05, 2010 2:20 pm
Yep, great idea! Thanks for sharing, Michael.
PostPosted: Sun Dec 05, 2010 3:22 pm
Coolness. As an aside, I used the guts to one of those lamps to make my pipe bender.
PostPosted: Sun Dec 05, 2010 4:14 pm
First name: Damon
Last Name: Wack
State: FL
Very nice! What was the type of glue? Do you think that will work with a titebond glued bridge?
Damon Wack
https://www.facebook.com/LindamonGuitars
PostPosted: Sun Dec 05, 2010 4:24 pm
Last Name: Hammond
I believe that with the application of heat almost all of the common glues will eventually give up. However, having said that, someone will find something that won't oblige.
PostPosted: Sun Dec 05, 2010 4:55 pm
First name: Rusty
Mike,
with the bridge plate and X-brace just on the other side, did you notice any softening of their glue joints?
PostPosted: Sun Dec 05, 2010 9:17 pm
A heat blanket can be controlled so you can dial in a heat . light is radiant and you can't control the temp other than time. I pull bridges cold with a chisel . You can use anything that makes heat to get a glue joint to fail . I prefer contact heaters , for control and less damage . You can fry finishes with lights if you are not careful. There are so many ways to do things , there is no one perfect way to do anything. If it works , that is all that matters .
PostPosted: Sun Dec 05, 2010 9:25 pm
Users browsing this forum: Lars Stahl and 27 guests
