It is currently Sun Jul 20, 2025 12:49 am
PostPosted: Mon Nov 08, 2010 9:55 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
My next build (#3) will be an OM, and I can't choose between a solid or slotted peghead... both are nice.
What are pros and cons of each?
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Tue Nov 09, 2010 5:29 am
I can't think of a "pro" for a slot head except they are old time. More work, harder to string up and to restring, not many choices in tuners.
I like 'em...
PostPosted: Tue Nov 09, 2010 8:32 am
About half of the guitars I have built are slotheads. As a result of doing that many I have overcome the PITA factor. A significant reason why it has become easy is having used the best routing jig I own. Check it out at http://www.luthiertool.com/triple_choice_slothead.html. Even stringing takes me no more time than for a solid peghead. The only con in my opinion is the extra finishing time required to deal with the slots and ramps.
As other cool builders have stated, it's cool to do slotheads.
PostPosted: Tue Nov 09, 2010 8:57 am
Well, that does look like the jewel of jigs, JJ. Costs as much too. Looks like I'll have to figure out a rational for getting that one!
PostPosted: Tue Nov 09, 2010 9:34 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I've built 3 OMs now and haven't even considered doing a slot head. I like all the options available for tuners with a solid head. Much easier for me anyway. I can't use the "Takes too much time excuse" because I waste way too much time just doing nothing.
Kent
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Tue Nov 09, 2010 10:02 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I've been building classicals and I haven't even thought of using a solid head!
After all the other work in building a good guitar, doing a slothead is not that difficult.
http://redrivercanoe.ca/
PostPosted: Tue Nov 09, 2010 10:17 am
One pro for a slothead is that they reduce the weight at the peghead by a noticeable amount, assuming you think that's a pro.
http://www.chassonguitars.com
PostPosted: Tue Nov 09, 2010 10:26 am
Yeah, I hate slot-heads too, especially the up charge.
PostPosted: Tue Nov 09, 2010 2:45 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Your avatar is argueing against you ;)
PostPosted: Tue Nov 09, 2010 3:19 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I've only done a couple of slot heads, but I really like 'em. Definitely has the cool factor.
I did the first without a jig & it's OK... But I wasn't completely happy with it. For the second I bought the LMI jig. Though not nearly as slick as the luthiertool unit, it works very nicely.
One piece of advice, though. Before doing the final shaping & sanding of the slots, make sure you have the clearance you need, so the E strings don't touch at the ends of the slots. On my last one, I can just get a five thou feeler guage between the string & the corner of the slot.
Some folks chisel a flat exit ramp at the bottom of the slots. This pretty much assures sufficient clearance.
PostPosted: Tue Nov 09, 2010 3:41 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
I have a jig for classical headstock slots that I could use. I'll just have to chisel down the slot ends to square, so ''too much work'' argument don't bother me here. Regardless of the work job, I just want to pros and cons on the finished product. Does it affect sound? Some body told me that slotted head decrease sustain and increase the ''crunchy attack''. I can understand how and why, but how much it's affecting, really. Also, i'm building this guitar for me, in the sense that I have no order, but I'll probably sell it one day, so is it a good hook or not for musician?
Thanks for the replies!
Francis
