D35 top depression http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=29809 |
Author: | Cecil [ Sun Nov 07, 2010 9:21 am ] |
Post subject: | D35 top depression |
I have a 1971 D35 on my bench for a neck reset. I don't do a lot of repairs. My experience is limited to working for friends and family. This instrument has a very pronounced depression between the sound hole and the bridge and the usual bulge behind. I can find no loose or damaged braces, The only thing that seams out of the ordinary is the cloth patch at the X brace intersection. It was applied very dry and the ends of the threads are frayed. It extends only a very short distance down the sides of the braces, (barley bast the rounded top portion). I really need some advise on how to handle this situation. TIA Cecil |
Author: | bluescreek [ Sun Nov 07, 2010 9:51 am ] |
Post subject: | Re: D35 top depression |
this is a typical thing on D35s. The lighter braces will tend to do this . Can you post a photo . To correct this you may need to pull the plate. Is that also deformed ? Call me I can tell you the procedure. |
Author: | Fred Tellier [ Sun Nov 07, 2010 9:58 am ] |
That is what they all do, I have yet to see a D35 more than 20 years old without this and many younger ones also. The structure will hold, set the neck to allow for this. I have seen a few that have had the bridge plate repaired and the owners lament the loss of sound. Fred |
Author: | Cecil [ Sun Nov 07, 2010 11:56 am ] |
I really can't believe the generosity the folks on this forum. I just talked to John Hall and he very carefully explained the procedure for correcting this problem. Thanks John and to all here who so generasly share thier knowledge. Cecil |
Author: | Mike Collins [ Sun Nov 07, 2010 6:20 pm ] |
I have two 70's era D-35s in the shop with the same problem. No loose braces-just a forward tilt of the top which causes the concave area in front of the bridge and the belly behind. This tilt also helps the guitar to play sharp-which is also a 70's Martin curse because the bridge was NOT glued in the correct position. I filled the saddle slot and routed a new 3mm(set back as far as I could go ) one that allowed better intonation & playabliity. Mike |
