Thicknessing fret board blanks. http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=29529 |
Author: | Fred Tellier [ Sun Oct 17, 2010 2:46 pm ] |
Post subject: | Thicknessing fret board blanks. |
What technique do you use the level and thickness fret board blanks. I have been using my thickness sander but have difficulty getting the top and bottom straight and parallel to my liking and spend way too much time on this step before it is acceptable. Fred |
Author: | Dave Stewart [ Sun Oct 17, 2010 2:57 pm ] |
Post subject: | Re: Thicknessing fret board blanks. |
Fred, I normally just joint, then resaw, then use a Delta planer .... works beautifully on ebony. |
Author: | ChuckB [ Sun Oct 17, 2010 3:03 pm ] |
Fred, I run mine through the thickness sander too. I don't have much problem getting it trued. Maybe your sander needs a slight adjustment? Chuck |
Author: | Alexandru Marian [ Sun Oct 17, 2010 3:23 pm ] |
I use a Jack plane at York Pitch. The blank is fixed between two 5mm tall stops that are clamped to the bench. What I like about planing is that I can correct, if not all, at least a good part, twisted or humped boards. I would imagine this is a bit more difficult to do with a sander? |
Author: | Alain Moisan [ Sun Oct 17, 2010 3:43 pm ] |
I just pass them through my planer until they reach the desired thickness. |
Author: | runamuck [ Sun Oct 17, 2010 4:39 pm ] |
Fred Tellier wrote: What technique do you use the level and thickness fret board blanks. I have been using my thickness sander but have difficulty getting the top and bottom straight and parallel to my liking and spend way too much time on this step before it is acceptable. Fred You could spend some time on your thickness sander getting the roller perfectly parallel to the table. Or you could send a piece of 3/4" MDF through, taking off just enough so you have sanding scratches all the way across. The MDF will now be parallel to the drum. Now just run your fretboards through on top of the MDF. You probably know this but it's best to make a fence on the near end of the MDF so the rotating drum doesn't catch a fretboard and throw it back at you. |
Author: | Joe Sustaire [ Sun Oct 17, 2010 5:20 pm ] |
Now that is a cool tip Jim! ![]() I know I've read that before as a simple fix for not quite parallel sanding drums, but I need reminding. ![]() Joe |
Author: | Fred Tellier [ Sun Oct 17, 2010 6:04 pm ] |
My parallel issues are not side to side but end to end. I get one side perfectly flat with the jointer but when I work the other it does not come out as flat as the 1st side. I also get a little snipe at the end at the start but use a long blank so it is not a problem. I made a flat carrier board to send it through on and it helps a little. I have resorted to putting wide masking tape under the thicker sections to flatten it out on the last passes. The boards come out fine when I am finished but it is more work than it needs to be, or maybe I am too fussy about my results. I check my work with a wide straight edge held on the board looking for light coming through from the lower areas. Fred |
Author: | Fred Tellier [ Sun Oct 17, 2010 6:38 pm ] |
Quote: A straight edge ain't tellin' you jack about what your sander's up to. It does when one side is still straight and the other is not after sanding. Like you say a little cup is ok. I think I am trying for more straightness than needed, but I am a little overboard sometimes. Fred |
Author: | Alain Moisan [ Sun Oct 17, 2010 6:48 pm ] |
Fred Tellier wrote: ... or maybe I am too fussy about my results. ... From my point of view, probably. I don't think it is necessary to have a surface that perfect for a fretboard. At least not at this stage in the process. |
Author: | alan stassforth [ Sun Oct 17, 2010 8:01 pm ] |
Hey Fred, it's good for a luthier to be a little overboard!!!! |
Author: | Mark Groza [ Sun Oct 17, 2010 8:50 pm ] |
Fred, I just take mine strait from the drumsander to a lapping plate( that gets it perfectly flat) just before glueing it to the neck that also is lapped on the plate. |
Author: | Terence Kennedy [ Mon Oct 18, 2010 1:52 pm ] |
I made a pusher and flatten one side on the jointer and sand the other side to proper thickness on my Performax. ![]() ![]() |
