| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Gluing fretboard before of after attaching neck http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=29454 |
| Author: | sprouseod [ Tue Oct 12, 2010 11:39 am ] |
| Post subject: | Gluing fretboard before of after attaching neck |
Fo those of you who subscribe to the idea of fretting and finishing the guitar with the neck and fretboard attached, do you find it easier to set the neck angle and attach the neck to the body before gluing on the fretboard or after? Thanks Richard |
| Author: | TonyKarol [ Tue Oct 12, 2010 11:51 am ] |
| Post subject: | Re: Gluing fretboard before of after attaching neck |
I glue the FB on first (the heel has been cut close to the ideal angle), the shape the heel and set the neck to the correct angel via flossing, all the while getting the heel to conform to the curve of the sides at the neck block (mine are not flat in that area) |
| Author: | ChuckG [ Tue Oct 12, 2010 1:20 pm ] |
My process is similar to Tony's. I determine the required neck angle by using a sliding bevel guage on the body and actually duplicating the exact angle. I then transfer this angle to the heel before gluing the FB onto the neck. I finish the neck and body separately, but do not fret until after finishing. Chuck |
| Author: | Alain Moisan [ Tue Oct 12, 2010 4:15 pm ] |
For myself. I fit the neck before the fretboard is glued to it, and while the neck is just roughly carved, with still some meat to remove from it. Than I glue the fretboard to the neck and finalize carving. I pore fill with the neck and body unattached, but finish with the neck screwed to the body (with FB extension glued to top). |
| Author: | woody b [ Tue Oct 12, 2010 4:46 pm ] |
Alain Moisan wrote: For myself. I fit the neck before the fretboard is glued to it, and while the neck is just roughly carved, with still some meat to remove from it. Than I glue the fretboard to the neck and finalize carving. I pore fill with the neck and body unattached, but finish with the neck screwed to the body (with FB extension glued to top). Same here, but I finish the neck and body separate, then install the neck. |
| Author: | Alain Moisan [ Tue Oct 12, 2010 4:57 pm ] |
sprouseod wrote: Fo those of you who subscribe to the idea of fretting and finishing the guitar with the neck and fretboard attached... By the way, I install frets before I glue the fretboard. |
| Author: | jsmith [ Tue Oct 12, 2010 7:39 pm ] |
After joining the neck to the body--making certain, of course, that the neck angle is not only correct for bridge height, but also that the neck is in line with the upper bout, I glue on the radiused but unfretted board. (NOTE: Although is shape the heel to finished form, I leave the neck-between peghead & heel--uncarved.) After 24 hours, I check that the board is still straight, then do my fret installation. Finally, I shape the neck. |
| Author: | Terence Kennedy [ Tue Oct 12, 2010 8:08 pm ] |
I get the cheeks pretty close with the jig I use to cut the tenon, then undercut them and using the actual fretboard as well as a centerline finder that keys in the truss rod slot I get things right where I want them The neck is partially shaped with the heel profile done at this stage. Then I glue the fretboard and do the final carving. If you are going to error on the neck set, error on undersetting it a little as that is a lot easier to correct than an overset once the fretboard is on. ![]()
