It is currently Sun May 17, 2026 6:20 pm
PostPosted: Sun Oct 10, 2010 10:34 am
Are water-based finishes such as Colortone nitrocellulose? Is the base lacquer the same as in solvent based lacquers and that the carriers (water versus solvent) is the main difference? If this were true, then could one apply water base lacquer over solvent based lacquer?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Sun Oct 10, 2010 10:42 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I found in my art world and using multiple types of paints/stains/finish that most any water base anything can go over a lacquer. Adherence could be a factor...so A test piece would be advised.
KB
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Sun Oct 10, 2010 11:07 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
No, waterbased lacquers like Colortone are acrylic, not nitrocellouse. You can't put Colortone over Nitro. Adhesion would be a problem.
PostPosted: Sun Oct 10, 2010 2:36 pm
Waterborne finishes are not nitrocellulose and are usually acrylic, but not always. KTM-SV is not acrylic. Test for adhesion should always be carried out over whatever sealer you use.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Sun Oct 10, 2010 7:56 pm
First name: sam
Last Name: hanssard
City: willcox
State: az
Zip/Postal Code: 85644
if the nitro is well cured the waterbase stuff may stick,however make sure you sand the nitro to de-gloss it. get rid of any slick surfaces.nothing sticks to slick. make sure you test first. with the way they are changing chemicals these days who knows for sure.
Users browsing this forum: No registered users and 322 guests
