| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Plugging tie block holes? http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=28985 |
| Author: | chinito [ Thu Sep 09, 2010 1:30 pm ] |
| Post subject: | Plugging tie block holes? |
Hi all, Drilled the holes in my padauk bridge and the sixth string didn't exit in line with the others. What's the best way to plug a misplaced hole in a classical bridge tie block? My thinking is it's mostly a cosmetic flaw. Then again I'm nowhere near gluing it on so I've got time to fix/replace it if it's more of concern.Thanks, Jake. |
| Author: | Mike Collins [ Thu Sep 09, 2010 2:43 pm ] |
| Post subject: | Re: Plugging tie block holes? |
How far out of line is it? I've seen lots of bridges like that from handmakers . Unless it's WAY off it should be NO problem I made a jig that I clamp the bridge to & drill 6-12-or 18 holes with . It's made of soft steel and is adjustable with shims for different tie block & bridge configirations Mike |
| Author: | chinito [ Sat Sep 11, 2010 2:31 am ] |
Thanks Mike! I had a luthier buddy check the bridge and he said the same thing. Sigh of relief. Looking at my pic, it's evident the other holes exit with a bit of variance anyway. The sixth is still the worst tho. ![]() Since drilling I filled the pores and gave the bridge a wash coat of shellac. I'm amazed at how much the colour came out once finish was applied. I knew padauk was red, but this stuff is like tomato sauce! -Jake. |
