Pictures of buffing setups, please http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=28825 |
Author: | Corky Long [ Sun Aug 29, 2010 12:37 pm ] |
Post subject: | Pictures of buffing setups, please |
Well, I think I've buffed my last guitar with the auto orbital buffer I've got. I've been using it for several years (7 guitars) and I'm tired of the shortcomings (read, user error). On the last, I was buffing the back, not realizing that a pebble of dried compound was under the top - even with the nice soft towel I had "pretecting" the top, I've got a nice divot in the top as a result of the vibration and pressure of the orbital buffer. How do you all buff? Where is your buffing arbor, and how's it set up? I've read that they are messy, with lots of dust from the process. Different room from your woodworking? Thanks. |
Author: | bluescreek [ Sun Aug 29, 2010 1:15 pm ] |
Post subject: | Re: Pictures of buffing setups, please |
I use the set up from Shop Fox. I also run it with a 1/4 hp motor , that is all you really need. The nice thing is that if you hang on to the guitar , you won't have it ripped out of your hands and tossed . That hurts big time. I have seen it happen and it gets real ugly . http://www.grizzly.com/products/Buffing-Assembly/H3559 I use the heavier buffing wheels that they have . I use a 14 and an 18. That is all that I use and I did have to make a bushing for the arbor. A Schedule 40 3/4 in pipe works for that |
Author: | Matthew Jenkins [ Sun Aug 29, 2010 2:48 pm ] |
Hi Corky I've just got the Stewmac buffing kit and I love it. I made a plywood base for the arbor and motor as recommended and attached it to my drill press table with a simple bolt. The drill press is itself bolted to the floor so there is no vibration movement at all. I have a small machine shop which is separate to my workshop. That was lucky ![]() ![]() The Stewmac kit was really expensive shipping to the UK but it was absolutely the best purchase I have made regards guitar building. It is really easy to use and provides excellent results. I have no knowledge of any other set up but I wouldn't hesitate to recommend the Stewmac kit. Mat |
Author: | woody b [ Sun Aug 29, 2010 4:10 pm ] |
This is the only picture I've got of mine. It's a Caswell 1100 RPM 3/4 HP. |
Author: | TonyKarol [ Sun Aug 29, 2010 4:15 pm ] |
homemade ... 16 bucks for the two bearings, motor was free from a bud, 1/5 hp, adn abotu ten bucks worht of wood. Another buddy turned the ends of the rod down so I could 1/2-13 tap them .... then nylon lock nuts, 1/4 ply wooden buff flanges ... about as cheap as they come ... those are 8 inch buffs, but a couple years back I went to the SM 12s .... |
Author: | woodbutcher50 [ Mon Aug 30, 2010 8:19 am ] |
Here's my homemade buffer. Attachment: IMG_1932 LF.JPG Shaft is 1" dia. x 54" long. The ends are threaded for LH and RH nuts.Three 14" flannel buffing wheels on each end with 1/2" plywood spacers between them. 1/2 HP motor @ 1725 RPM is reduced to about 735 RPM @ the shaft. The whole setup cost nearly the same to build as the new StewMac, but the the clearance is phenomenal. I built the base out of 2 layers of 3/4" plywood so it would nestle in the frame at the end of my thickness sander. Mark |
Author: | SteveSmith [ Mon Aug 30, 2010 8:41 am ] |
So Mark, is that a Go Kart axle? |
Author: | joe white [ Mon Aug 30, 2010 6:07 pm ] |
My setup is simple as well. Since I require four wheels to get the results that I am after, I use two of the caswell machines and they have served me well for the last three years. Lots of padding and no hard edges! |
Author: | James Orr [ Mon Aug 30, 2010 7:27 pm ] |
Hey Joe, what kind of buffs do you use? |
Author: | meddlingfool [ Mon Aug 30, 2010 9:46 pm ] |
Yes, please do tell. I have one of those machines but the wheels must be the wrong type as all I can do is fine buffing. Could you let us know size/style or a part number? It would be very appreciated... |
Author: | Mike Franks [ Mon Aug 30, 2010 9:57 pm ] |
You have all been treated to a rare photo of Joe's "Cave" hidden deep in the bowels of his Skunk Works! Mike Franks www.mjfranksguitar.com |
Author: | joe white [ Mon Aug 30, 2010 10:36 pm ] |
Filippo Morelli wrote: Hey Joe, love the white room. But shouldn't that be a straightjacket hanging on the wall instead of a black apron? Filippo Only when the wheels grab one of Mikes Brazilian style 45 OM's and throws it across the floor. ![]() As for the wheels, I am running 16x5x3/4 16 ply #2 60/60 cotton wheels on the heavy cut machine. Two wheels per side. On the fine cut machine, I run 16x5x3/4 12 ply #2 Domet wheels, two per side. You will need six inch flanges to safely run these wheels since the center hubs are five inch. My wheels can be found at Menzerna USA also known as Jescar. Ask for Jeff Silver. He can be a bit grumpy and almost impatient at times but the dude knows his stuff about guitar buffing. |
Author: | Corky Long [ Tue Aug 31, 2010 12:46 pm ] |
Thanks, all for the great input and pictures of your setups. (And thanks, John, for the reminder on not having the buffer become a "Git-apult". I guess there are risks to all these processes. I sure don't want to spend months on a guitar, then have it be made into kindling while buffing) |
Author: | npalen [ Tue Aug 31, 2010 1:20 pm ] |
Joe, nice setup! You make us all jealous. Have you ever considered being a professional instrument finisher? ![]() Best regards Nelson |
Author: | enalnitram [ Tue Aug 31, 2010 1:51 pm ] |
bluescreek wrote: The nice thing is that if you hang on to the guitar , you won't have it ripped out of your hands and tossed . That hurts big time. I have seen it happen and it gets real ugly . When I worked at Washburn I saw this happen to a few guys and I always thought, "huh, they just need to be more careful." so one day I'm buffing a solid body electric guitar, heavy like a les paul, and the machine ripped the guitar out of my hands and threw it, full force, right at my big toe! I don't even know how it happened, it went so quick. I recommend avoiding doing that if at all possible! fortunately it was the only accident i was involved in while working at that factory. |
Author: | meddlingfool [ Tue Aug 31, 2010 4:26 pm ] |
Joe, Thanks for the info! |
Author: | woody b [ Tue Aug 31, 2010 6:42 pm ] |
A note for everyone. I don't think 16" wheels on a 1100 RPM machine are a good idea with anything except a Polyester finish, and a bunch of experience. |
Author: | Darryl Young [ Tue Aug 31, 2010 8:49 pm ] |
woody b wrote: A note for everyone. I don't think 16" wheels on a 1100 RPM machine are a good idea with anything except a Polyester finish, and a bunch of experience. What are you trying to say???? ![]() ![]() |
Author: | Mike OMelia [ Tue Aug 31, 2010 10:34 pm ] |
Man! I thought by now Rod True would post a pic of his hand! (his buff setup) |
Author: | woodbutcher50 [ Wed Sep 01, 2010 6:15 pm ] |
Steve, It started out as a piece of cold rolled steel. The machining turned out to be the biggest expense. If I was doing it again, I'd either go with 7/8" dia. or 1-1/4" dia. All the flanges I saw for vented wheels were these two sizes. Mark |
