It is currently Mon May 11, 2026 10:01 pm
PostPosted: Tue Aug 17, 2010 12:49 pm
Last Name: Sollod
Is this product dewaxed? Would I have problems using it under different finishes?
- waterborne acrylic?
- lacquer?
- Tru-Oil?
www.swiftcreekguitars.com
PostPosted: Tue Aug 17, 2010 12:55 pm
The only Zinsser product that I am certain is dewaxed is the "Seal Coat."
PostPosted: Tue Aug 17, 2010 3:16 pm
Yes, it even says it's dewaxed on the can. You have to look for it, but it's there, somewhere.
PostPosted: Tue Aug 17, 2010 3:21 pm
First name: Tracy
Last Name: Leveque
State: CO
- lacquer?
- Tru-Oil?
Steve,
This is the product I use for sealing my binding channels so super glue doesn't seep into the end grain of the top or back. I also use it for sealing the rosette channels so the super glue doesn't bleed into the top. I'm pretty sure it is dewaxed, but if it doesn't say on the can, then don't use it under finish.
PostPosted: Tue Aug 17, 2010 9:21 pm
Last Name: Cox
I had trouble with Varnish wanting to do strange things when brushed over Shellac....
Specifically -- I ended up with little funny looking bubbles when it sat in a hot car.... Didn't happen when I brushed the varnish straight onto the wood....
I also ended up with an instance of Varnish peeling off of the shellac -- apparently, the Varnish didn't "Bite" into the shellac -- and it just lays on top of it....
Since then, I brush a "Spit coat" of varnish onto the wood and let it dry a while to protect from dings and act kinda like a seal coat....
Tru-Oil is a varnish -- so I might check it on scrap 1st -- just to make sure it bonds well... It may work just fine for you...
PostPosted: Tue Aug 17, 2010 10:45 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Todd Stock wrote:
Shellac needs to be well toothed before most topcoats go on...it's a good barrier coat, but bonds depend on both mechanical bonding (keying) and the usual molecular forces to keep things stuck. Tooth the shellac just prior to topcoat...bond will be stronger on a fresher, more energetic surface.
This is fascinating. Can You give us more information about the research on this?
PostPosted: Wed Aug 18, 2010 11:59 am
Last Name: Sollod
Thanks for the comments... [:Y:]
I do want to put Tru-Oil over the Zinsser (spray can) shellac. I was planning to sand the shellac with 220 first. Is this a good plan? Has anyone done this? Any more comments before I move forward?
Users browsing this forum: No registered users and 140 guests
