http://www.luthiersforum.com/forum/
sound hole cutting before or after thinning ?
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=28185
Author:  segovia [ Mon Jul 12, 2010 5:37 pm ]
Post subject:  sound hole cutting before or after thinning ?
I have joined two tops of spruce and inlaid my rosette.
Should I thickness it to the final thickness and then cut the sound hole or cut the sound hole and then final thickness?
J
Author:  StevenWheeler [ Mon Jul 12, 2010 5:45 pm ]
Post subject:  Re: sound hole cutting before or after thinning ?
I thickness first.
Author:  Steve Saville [ Mon Jul 12, 2010 5:47 pm ]
Either way will work. I thickness first, but I think I'm in the minority.
You'll want to install your rosette before you cut out the sound hole.
Author:  James W B [ Mon Jul 12, 2010 5:48 pm ]
I usually thickness it and make sure everything is cool with the rosette.Like making sure it is flush with the top.Then I`ll usually thickness from the back side of the top and then cut out the sound hole. James
Author:  DennisK [ Mon Jul 12, 2010 6:08 pm ]
My sequence is join, cut to oversize guitar shape, thickness (hand planes), rosette, cut soundhole.
Easier to sand the rosette flat to the surface if there isn't a hole to fall into, and there's no real advantage to cutting it early, that I'm aware of.
Author:  Terence Kennedy [ Mon Jul 12, 2010 6:57 pm ]
I'm usually tapping the top and feeling deflection during final thicknessing so I do it after I cut the sound hole. I Install the rosette while still thick and sand flush from the top then cut the sound hole and thickness from the back.
