http://www.luthiersforum.com/forum/
slot head question
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=27784
Author:  jsmith [ Fri Jun 11, 2010 11:36 am ]
Post subject:  slot head question
To those who build steel strings with slotted pegheads: What is the distance from the center of the post on the first and third tuners of either side to the end of the respective slot? In other words, how much room is necessary to make it easy to change strings?
Author:  John How [ Fri Jun 11, 2010 1:40 pm ]
Post subject:  Re: slot head question
Typically the distance between each peg is 1 3/8", my slots are 4" long with the holes centered on that, so just a little over 1/2" on either end of the outer pegs.
Author:  jsmith [ Fri Jun 11, 2010 1:44 pm ]
Thanks for the reply, John. Actually, I'm not looking for the spacing between the tuners posts themselves, but the amount of space between the tuner posts and the ends of the slots, to determine how much space is needed to facilitate changing strings.
Author:  meddlingfool [ Fri Jun 11, 2010 2:12 pm ]
Er,...John's reply answered your question ... Just a little over half an inch.
Author:  Quine [ Fri Jun 11, 2010 2:39 pm ]
1/2 inch is what I used and it looks about right. My slots have semi-circular ends, so that's 1/2 inch from post to the top of the semi-circle
You can use more or less depending on what looks good to you. You don't need that much space to clear the string windings
Author:  jsmith [ Fri Jun 11, 2010 6:57 pm ]
Thanks, Quine. I actually just came up from the shop after making a jig with 1/2" of clearance, and it looks right to me, too.
