http://www.luthiersforum.com/forum/
Tools, tips for measuring/documenting guitars?
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=27749
Author:  John Bushouse [ Wed Jun 09, 2010 12:05 am ]
Post subject:  Tools, tips for measuring/documenting guitars?
I have the opportunity to check out some really cool old guitars, and I'd like to document everything I can about them. Things I've thought about doing/materials I'll need:
[list=*]
[*]A good camera
[*]Big sheets of paper or poster board to trace the bodies using a half-pencil
[*]Large straightedge and/or framing square to use in taking pictures
[*]Good quality calipers - nut width, string spacing, thicknesses of various parts (headstock, neck, etc.)
[*]Inspection mirror
[*]Light source to stick inside the guitar to check out the bracing pattern through the top[/list]
Other things?
Author:  JohnAbercrombie [ Wed Jun 09, 2010 12:26 am ]
Post subject:  Re: Tools, tips for measuring/documenting guitars?
Neat opportunity! Be careful!
- some old blankets or towels for padding your work table
-(be careful with your measuring tools- a framing square or steel straightedge can do a lot of damage)
- a checklist or a form to make sure you don't forget any of the critical dimensions & data
- pre-cut your posterboard into usable pieces (body, headstock profile)
- a few good quality rules 12" and 18/24" or metric equivalent (you want to get the scale length)
Author:  SteveG [ Wed Jun 09, 2010 12:29 am ]
If you are really serious about this you might consider a hacklinger thickness gauge.
http://www.stewmac.com/shop/Tools/Measu ... Gauge.html
Expensive, eh?
cheers
Author:  Lillian F-W [ Wed Jun 09, 2010 9:52 am ]
Any thoughts on a lighting set up to take an "x-ray" of the bracing.
Author:  Dave Stewart [ Wed Jun 09, 2010 10:04 am ]
Regarding the magnets Todd mentioned, you might want to check out this MIMF thread (login req'd) http://www.mimf.com/library/measure_aco ... racing.htm
Author:  Tim L [ Wed Jun 09, 2010 10:14 am ]
Todd,
Great idea for a transfer guage. Not that I'm looking for another project, but that looks like it would work too good not to have one.
Tim
Author:  Brock Poling [ Wed Jun 09, 2010 3:11 pm ]
I think if you are really serious about it an x-ray, hacklinger guage, and a surgical scope you can put a camera on would be excellent tools to have.
Author:  John Bushouse [ Wed Jun 09, 2010 5:17 pm ]
Does anyone know how I would go about getting an X-ray of the guitar, and a rough idea of how much it would cost? That's a dream of mine, but I assume it's far too cost prohibitive (and not covered by insurance :))
Author:  Lillian F-W [ Wed Jun 09, 2010 9:36 pm ]
I know that someone used their local airport late at night to have a peek at their guitar.
By "x-ray", I meant using a bright light inside the guitar and taking a picture of it in a dark room. What light set up has me strumped though. Everything I have tried is either too dim to work or gets too hot for me to be comfortable leaving it in there.
Author:  Lillian F-W [ Wed Jun 09, 2010 11:15 pm ]
I'm a bit apprehensive about dropping a rare earth magnet into a 170ish year old Martin 1, but much less so than sticking a heat source into it. Definitely going to have to practice it first.
Author:  John Bushouse [ Wed Jun 09, 2010 11:49 pm ]
Some uber-bright fluorescent bulbs, or some LED light source, should provide enough light without the heat.
I figure the "X-ray" image will help to identify stuff that might not be so evident - repairs, odd braces, etc.
Author:  Kim [ Thu Jun 10, 2010 12:16 am ]
Here's and idea that just popped into me head Lil', how about a standard SLR hotshoe camera flash?? You set the flash up inside the guitar and cover the soundhole, set camera on a tripod, the ISO to 'fast', set the focus manually, set the shutter for a long exposure, turn off the lights so you are in complete darkness, open the shutter, trigger the flash, and you got ya xray. [:Y:]
Author:  John Ray [ Thu Jun 10, 2010 1:34 am ]
I have examined quite a few historical instruments and often the problem is not damage to the instrument while measuring but rather making the owner feel like proper care is being taken. I use plastic rules and calipers which are not so accurate but the errors inherent in this sort of examination are greater anyway. As for a light source the trick is to have a dark room, that way you can use a mosdest fluorescent bulb which hardly gets hot to the touch. One handy thing I have made is a small tool which allows me to straddle the braces and lower a "piston" to accurately measure brace height. A plane and some scraps of wood close to the imagined brace separation will allow you to plane the wood until it just fits between the braces.
John Ray
Granada
Author:  Eric Reid [ Thu Jun 10, 2010 3:03 am ]
The Unofficial Martin Guitar Forum has a lengthy thread on photographing brace patterns. there are suggestions for lighting and examples of results. Page 18 of the thread has an x-ray of a 1937 D-18. The resolution is great. If you can x-ray the guitar, do it (and post your results).
Author:  Pat Foster [ Thu Jun 10, 2010 1:04 pm ]
You could get info on resonant frequencies of the top, back, main air, perhaps weight of the instrument.
Lillian,
For "x-rays" I use two compact fluorescents inside the guitar, and block the soundhole as well as I can. The two light sources minimize shadows. I put the camera on a tripod, turn off the flash, dim the room lights, and hit the button. Sometimes I need to use exposure compensation.
Author:  Lillian F-W [ Thu Jun 10, 2010 9:44 pm ]
Thanks for the info about the magnets Todd. Much appreciated.
Pat, what wattage works best?
Author:  JohnAbercrombie [ Thu Jun 10, 2010 10:03 pm ]
If you don't have a digital camera that can accept a 'cable release' (actually an electronic switch these days), it can help to reduce 'shake' and blurred pictures if you use the self-timer. The 10s delay lets the shakes die down a bit before the exposure starts.
IMO, having a decent tripod is the key, as Pat mentioned.
Author:  Lillian F-W [ Thu Jun 10, 2010 10:23 pm ]
What constitutes a "good" tripod?
Author:  JohnAbercrombie [ Fri Jun 11, 2010 12:15 am ]
Lillian-
Heavy-duty enough that it doesn't shake!
A lot of the ones I see (in the 'cheap stores' where I shop ;) ) look like they were made with 3 car radio antennas strapped together- they are pretty wobbly.
One alternative to a standard ('floor-model') tripod is a 'mini-tripod' or 'tabletop tripod' - some of them are quite solid.
BTW, probably not bright enough for the 'X-ray vision' thing, but 'string/tube' LED lights (LEDs in a plastic tube) are handy for working inside guitars.
Author:  Lillian F-W [ Fri Jun 11, 2010 6:30 am ]
Thanks John, I'll start looking around for a decent tripod.
Tried the LED's and that didn't work at all. Which is why I posed the question. I know its been done, seen the pictures, but I couldn't find any real information on the light source other than "use a bright light".
Author:  Lillian F-W [ Sat Jun 12, 2010 7:22 pm ]
I asked my brother and he's gotten rid of his SLR equipment when he got is itty bitty digital.
Author:  LPMc [ Sat Jun 12, 2010 10:04 pm ]
Just looked into a 1943 Martin 0-18 today. Dropped in a refrigerator light into the upper bout (behind the camera) and used a cell phone camera for the pic - not perfect, but good enough to begin measuring.
