http://www.luthiersforum.com/forum/
New Soundhole/Rosette Jig Prototype In The Works
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=27643
Author:  Chris Paulick [ Tue Jun 01, 2010 7:21 am ]
Post subject:  New Soundhole/Rosette Jig Prototype In The Works
I posted this in the Shops Post but thought I'd post it here too to see what your thoughts on it might be.
This is the prototype and I'm still in the R&D of it. I plan on adding a mini air pencil grinder to it with a percision adjustment simular to the axis adjustment. Changing the axis changes the ellispe shape and changing the pencil distance changes the size. It's based on John Farey's early Ellispograph from 1810 and on HAFF drawing instruments adaptation of it and now my adaptation of it for Lutherie use, I Hope :P As it stands now it's just a ellispograph until I add the air grinder. I have a cheap HF for the prototype. Do you all see the use for this or is it just me?
Author:  tim88 [ Tue Jun 01, 2010 7:37 am ]
Post subject:  Re: New Soundhole/Rosette Jig Prototype In The Works
Looks interesting Chris. Will it have the ability when finished to actually CUT the rosette channel or is it strictly for drawing and scoring?
Author:  Elman Concepcion [ Tue Jun 01, 2010 8:51 am ]
Can I assume it will draw plain boring circles?
If it could also cut - I would buy one!
Author:  Terry Stowell [ Tue Jun 01, 2010 8:52 am ]
Tim he explained that he was going to add a die grinder. Some may not know what it is. It's an air operaterd, high speed rotary tool (grinder, router, etc)
Author:  tim88 [ Tue Jun 01, 2010 8:58 am ]
Yea he said he was switching the pencil out for a "mini air pencil grinder". Wasn't sure what that was , was thinking some kind of scribing tool, but now that you say "die grinder" I bees understanding, duh lol .
Author:  douglas ingram [ Tue Jun 01, 2010 9:01 am ]
Oh, I can definitely see the uses for it, I would just need to see it used a LOT to make it worth the effort to build such a beautiful example as you have presented. For my own uses, I can't see that I would use it enough.
Well done from both a research and execution point of view!
Author:  Terry Stowell [ Tue Jun 01, 2010 9:04 am ]
Here's a little better pic... They run pretty high rpm's I'm thinking 80K.... Pic of Todd Stock's grinder in use. I think Blues Creek Guitars made this base , IIRC. More tools are better, no?
Author:  Chris Paulick [ Tue Jun 01, 2010 10:48 am ]
Yes it will do circles by setting the center/ axis offset at zero. There are two holes at 3" off center that can be pinned so the plates are inline. They were also used to locate the plates for the milling process and locate the plates in the jigs I had to make to make the jig. It's not like I have a CNC , I'm old school and that would be too easy plus I'd have to take the time to learn CAD. :) Once I perfect it I could always farm that out if I find a need for these. The thing is it can be used to make templates for routing guides also. I started out by trying to look for ellispe templates for a sound port and a set was from $50 on discontinued sale to $90. I'm planning on cutting a template with it into plexi for the soundport and then heating the plexi and forming it to the guitar side and then routing it out or maybe just using 1/16" poly and make a guide bushing for the mini grinder or just hand cut it. I bought the cheap HF grinder just for the Prototype because cash is at a low right now. Maybe I should give John a call.
Author:  alan stassforth [ Tue Jun 01, 2010 11:03 am ]
very cool, chris!
i spent an hour yesterday watching your vids on the router base, radius jig, and binding cutter jig.
you are a saint.
good actor too!
alan
Author:  Chris Paulick [ Tue Jun 01, 2010 11:19 am ]
Actor??? This is True Reality TV! :D
Glad to be of some help.
