http://www.luthiersforum.com/forum/
I want to see...
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=27562
Author:  Gtrman13 [ Tue May 25, 2010 11:30 am ]
Post subject:  I want to see...
Parlor soundboard bracing! I'll be bracing an adirondack soundboard for a parlor guitar soon and I just want to see others' work before I start.
Oh, and one more question. I'll be using a gobar/radius dish setup for the first time. Am I correct in assuming that the bridge plate should be glued on a flat surface instead of the radius dish?
Thanks all!
Author:  Haans [ Tue May 25, 2010 2:04 pm ]
Post subject:  Re: I want to see...
Here's a couple, most of us ladder guys use some form similar...
If you are using a dish, most folks radius the bridge to match the dish.
Author:  woody b [ Tue May 25, 2010 5:09 pm ]
This is a really small Parlor. The lower bout is 10 7/8" (If you notice the saddle compensated....wrong in the finished picture it's left handed)
Author:  Daniel Minard [ Wed May 26, 2010 11:31 am ]
I sand my bridge plates in the radius dish before I glue them in place.
Author:  Terence Kennedy [ Wed May 26, 2010 12:25 pm ]
Here's one of mine. Size 2. I've been splaying the X a little more and using a slightly longer bridge to overlap the corners. Oldest one is three years and no sign of structural problems so far. These days I'd have a shorter taper on the ends of the upper top brace.
Author:  Gtrman13 [ Thu May 27, 2010 5:40 pm ]
Thanks for the replies, guys! Exactly what I needed.
