| Official Luthiers Forum! http://www.luthiersforum.com/forum/ |
| Truss Rod Help http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=27456 |
| Author: | tim88 [ Wed May 19, 2010 8:16 am ] |
| Post subject: | Truss Rod Help |
Can anyone tell me what kind of truss rod this neck is cut for. I tried to contact the guy I bought it from but the number is disconnected. It's about .262 wide and .400 deep and the slot is .385 wide and .475 deep. |
| Author: | JohnAbercrombie [ Wed May 19, 2010 12:00 pm ] |
| Post subject: | Re: Truss Rod Help |
Tim- If you check the supply places (LMII,StewMac,Allied) you should be able to find a rod that fits . You can always glue in some shims into the wider area of the slot if necessary- some rods use an even-width slot all the way. The slot is generally a bit deeper than the rod, to allow for a cover strip of some kind. Here's a chart from LMII... |
| Author: | SteveCourtright [ Wed May 19, 2010 1:01 pm ] |
That looks like a Martin neck to me, correct? If so, you should get a Martin rod. |
| Author: | cwood8656 [ Wed May 19, 2010 1:04 pm ] |
I agree with Steve. That looks like a Martin neck routed for their two way truss rod. Chris. |
| Author: | tim88 [ Wed May 19, 2010 2:22 pm ] |
Yep it is the 2 way truss rod Martin is using now. They said they started using it about 3 years ago. Thanks for the help |
| Author: | bluescreek [ Thu May 20, 2010 6:53 am ] |
This is a Martin 2 way truss rod style neck . here is a link to a truss rod . I do stock them . http://www.bluescreekguitars.com/catalo ... cts_id=128 thanks john |
| Author: | tim88 [ Thu May 20, 2010 7:03 am ] |
Thanks John, if I had known you stocked them I would have bought it from you but have already ordered from Martin. Tim |
