Thicknessing with a hand held sander? http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=26444 |
Author: | JimH [ Wed Mar 10, 2010 5:18 am ] |
Post subject: | Thicknessing with a hand held sander? |
Is it a good idea to thickness with a hand held power-sander? They're obvsiouly much cheaper that buying a thicknesser and can be useful for other jobs Thanks. |
Author: | Mike OMelia [ Wed Mar 10, 2010 6:21 am ] |
Post subject: | Re: Thicknessing with a hand held sander? |
I would think uniformity to be the issue. However, back in the day it was done with planes and scraping. But a thickness sander is so much faster and no buzzing hands. Look on line regarding the Safe-T Planer. Also, there are some web pages describing how to thickness with a router. |
Author: | Jim_H [ Wed Mar 10, 2010 6:24 am ] |
JimH wrote: Is it a good idea to thickness with a hand held power-sander? They're obvsiouly much cheaper that buying a thicknesser and can be useful for other jobs Thanks. Nice Name =) |
Author: | Phillip Patton [ Wed Mar 10, 2010 8:20 am ] |
JimH wrote: Is it a good idea to thickness with a hand held power-sander? They're obvsiouly much cheaper that buying a thicknesser and can be useful for other jobs Thanks. I used a 3x18 handheld belt sander to thickness three of my four guitars. It works, but it's obviously not as good as a thickness sander. The trick is to keep it moving; you don't want gouges in your wood. Uniformity isn't too difficult to achieve, once you've had some practice. |
Author: | Marcus [ Wed Mar 10, 2010 12:18 pm ] |
I do it. I would much rather have a thickness sander, but like you, they are a bit spendy for me at this time. To save yourself some time, you can buy those metal sanding discs at an Ace Hardware. They arent needed for a soundboard, but those hardwoods can take all day to sand down with 80 grit. |
Author: | Glenn LaSalle [ Wed Mar 10, 2010 5:39 pm ] |
Before I got my Performax 10-20, I worked a couple tops using Planes, and finished off with my ROS. Seemed to work great ... just that the performax is much faster ![]() Glenn |
Author: | David LaPlante [ Wed Mar 10, 2010 6:09 pm ] |
I used to do joined tops this way long ago with my Porter cable palm sander (A belt sander is WAY too aggressive for spruce). Using a soft carpenter's pencil, mark the entire surface with cross hatching pressing just hard enough to slightly indent the marks. Sand away (80 grit) until the marks are gone and repeat. Stick to 80 grit, anything coarser than 80 grit will shed bits of abrasive that will embed themselves into the soft surface of the spruce marring it. This works fine. The only drawback is that it takes time and you must be careful to sand evenly to the point that you then may want to thin certain areas additionally. |
Author: | bill stewart [ Thu Mar 11, 2010 11:40 am ] |
I suffer from arthritis so I find it hard to hand plane hardwoods (plus getting old). I use a hand held Bosch electric planer to take down the bulk of the wood from the usual 4 to 5mm to just over 3mm and then take down to final thickness on my home built thicknesser/sander. Yes this can be scary with a hand held power planer if your not careful. ![]() Bill S. |
