It is currently Thu Aug 07, 2025 8:40 pm
PostPosted: Wed Feb 24, 2010 10:47 am
Hello all and in particular fellow scrapers. I almost exclusively use scrapers now to get the backs and sides smoothed out before finishing. But I cannot seem to get the softwood tops perfect. The scraper seems to dust up more then curl up the wood and looking with a 10x loop I can see fibers tearing out.
So I am wondering if others out there have any suggestions. Perhaps a particular scraper or sharpening technique or maybe just use sand paper?
Regards.
PostPosted: Wed Feb 24, 2010 1:04 pm
The softer the wood, the sharper the scraper needs to be but yes. softwood is more difficult...... dust usually means it's not sharp enough.
Milton, ON
PostPosted: Wed Feb 24, 2010 2:10 pm
A light, sharp burr is the key, along with a light touch.
Even so, the scraper will cut the harder latewood grain more than it does the early wood, which will tend to compress. After a while the earlywood swells back up, and you end up with a sort of 'corduroy' effect. This is very much sought after by the violin crowd, since that's what Strad did. On guitars it's usually seen as a defect, so be prepared to defend yourself.
PostPosted: Wed Feb 24, 2010 4:05 pm
PostPosted: Wed Feb 24, 2010 4:37 pm
First name: Tracy
Last Name: Leveque
State: CO
Go to this page http://www.lmii.com/CartTwo/Video.asp and go to the 2nd to last entry at the bottom. All about scrapers. Hope that helps!
PostPosted: Sun Feb 28, 2010 1:28 pm
Thanks for the advice. The video is good and lots of others to see too :) I sharpen a bit differently though. What I do is file the 90 deg face just like in the video but I then file off the burr and hone it with a stone. Then I lay the scraper flat and draw out a bur with the burnisher. Seems to me that just using a file would have micro nicks along the burr making the cut a bit rough. But it looked good in the video and is a bit easier to do too.
