DIY precision router base and circle cutter http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=26198 |
Author: | djmrozinski [ Mon Feb 22, 2010 7:06 pm ] |
Post subject: | DIY precision router base and circle cutter |
Just wanted to post a pic of the precision router base and circle cutter I put together. The router support is tapped for a dremel. Just move the router support and the threaded rods between the router base and the circle cutter. The only thing not shown is a knob to tighten the circle cutter diameter adjustment pin. Just looking for some feedback and thoughts. Going to try it out routing for my first rosette installation next week. Attachment: Router_circlecutter.JPG Thanks Dave djmrozinski@chartermi.net |
Author: | Colin North [ Mon Feb 22, 2010 7:40 pm ] |
Post subject: | Re: DIY precision router base and circle cutter |
Looks really good! ![]() I bought mine in UK, but would have made one if I thought I could have made as good a job as your one looks to be. Only thing I might suggest is the wing nuts you are using for depth adjustment might be a little tricky to adjust evenly - mine has large brass wheels with milled edges for fingertip fine adjustment. Should easy for a man of your resourcefullness to make something similars for yours, if you find it a little tricky I like the use of see-though plastic, mine is all metal. |
