http://www.luthiersforum.com/forum/
Looking for Neck Block ideas (Steel String Build)
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=26019
Author:  Brad Simmons [ Thu Feb 11, 2010 8:58 pm ]
Post subject:  Looking for Neck Block ideas (Steel String Build)
I have been looking around for a few ideas regarding a neck block for a steel string build. Anyone care to chime in. I will be using a tenon joint for my 1st build.
Brad
Author:  StevenWheeler [ Thu Feb 11, 2010 10:19 pm ]
Post subject:  Re: Looking for Neck Block ideas (Steel String Build)
Brad,
My favorite is the one that Colin Symonds posted. Search neck joint and put Colin S in as the author. You'll come up with this.
Author:  Corky Long [ Fri Feb 12, 2010 11:04 am ]
Brad -
William Cumpiano's site has a clear and simple explanation of the M&T neck joint that he now uses, supported by KD bolts. I like it a whole lot better than the dovetail that I mangled on my first three guitars....
Author:  Brad Simmons [ Fri Feb 12, 2010 8:52 pm ]
Thanks for the advice, I appreciate it.
