It is currently Wed Aug 06, 2025 6:26 pm
 Post subject: Bending Myrtle
PostPosted: Mon Jan 18, 2010 8:22 am
I'm looking for advice on bending Oregon Myrtle. How difficult/easy is it to work with? What about bending temperatures? I've not worked with it before, but I got a couple of very pretty sets and think they might make nice flamencos.
Max
Max Bishop
Brighton, Michigan
 Post subject: Re: Bending Myrtle
PostPosted: Mon Jan 18, 2010 9:26 am
Unless highly figured it bends easy 275-310 wood dry covered in damp kraft paper or wood light spritz wrapped in aluminum foil. If highly figured you may want to treat with SSII a couple day isn advance and use the same temp and moisture treatments
PostPosted: Mon Jan 18, 2010 10:15 am
I have bent two sets over a bending iron and both were easy. The first set, which was fairly curly, was easy to thickness with a hand plane (well, easier than rosewood, for example). You will love working it.
PostPosted: Mon Jan 18, 2010 11:53 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Myrtle makes great FLamencos !
Many of the sets I have have a(highly figured) twisting grain pattern much like African Mahogany.
So bending can be a problem'I treat it like MDP has already written.
Also some Myrtle is more brittle and splits easy.
Take your time and go slow.
Mike Collins
PostPosted: Mon Jan 18, 2010 12:19 pm
Myrtle is one of the easiest woods to bend. I bend at 300 degrees and regardless of figure it bends like walnut. Great stuff too...
PostPosted: Mon Jan 18, 2010 12:51 pm
yes, my experience is like Peter's.
easy easy to bend.
love the stuff!
steve
PostPosted: Mon Jan 18, 2010 2:43 pm
Thanks, everyone for your input.
Mike Collins wrote,
Mike, could you tell more about your experience with making flamencos from myrtle? How would you characterize a flamenco made from myrtle as compared to cypress?
Max
Max Bishop
Brighton, Michigan
