It is currently Sun Jul 20, 2025 1:44 pm
PostPosted: Mon Dec 21, 2009 10:49 pm
First name: Darryl
Last Name: Young
State: AR
I'm wanting to reinforce the rim of my first build in case I want to add a soundport later. So I'm trying to decide what shape would look nice and would love to see your ideas for soundport shapes. I would also like to hear your thoughts on soundport shapes and location. Seems I read that when locating in the uper bout toward the player, that placing near the top gives a better sound. What are your thoughts?
Thanks, and Merry Christmas!
PostPosted: Tue Dec 22, 2009 4:35 am
First name: Sen
Last Name: Goh
Country: Singapore
I placed my sound port at only one side at the edge of the upper bout which was the best position according to Al (Carruth).
The inside was line with a basswood reinforcement.
The shape was 2 tear drop which forms a S in the middle.
So far when I played it, the effect of the soundhole was very clear: I could hear myself playing just like I was sitting right in front of the guitar.
Sen CL Goh
http://senguitar.blogspot.com
PostPosted: Tue Dec 22, 2009 9:07 am
First name: Darryl
Last Name: Young
State: AR
Very nice Sen.....creative way to place your initial in the soundport design. Also, the edge of the soundport looks nice with the contrasting, light colored basswood. Did you have to bend the basswood or was it pliable enough at that thickness to conform to the curve of the upper bout?
I'm torn on using thin aircraft ply or using a thcker, solid wood similar to what you've done. The solid wood left thicker may give the edge a nicer appearance. I'm not going to open up the soundport initially but I want it as an option later since my soundhole on my top is undersized similar to a Norman Blake soundhole.
PostPosted: Tue Dec 22, 2009 9:32 am
First name: Matt
Last Name: Rispoli
State: NJ
It came out great. [clap]
PostPosted: Tue Dec 22, 2009 10:30 am
First name: Sen
Last Name: Goh
Country: Singapore
Thanks for your compliments.
I did bend the basswood before gluing to the side.
It was very easy to bend just wet it with some water and bend it on the heat pipe.
The thickness of the basswood was about 2mm.
Hmm I have limited experience with this actually.
But I guess any sort of reinforcement will be better than having none at all.
My choice for basswood is that it's light and easy to bend.
I guess even some scrap spruce top might also do the trick too...
So even if you don't ever do the sound port it probably won't affect anything.
Sen CL Goh
PostPosted: Tue Dec 22, 2009 10:34 am
First name: Evan
Last Name: McCartney-Melstad
Here's mine:
It's a little tough to see from the angle, but I was going for a four-point Celtic knot.
The interior bits are actually pretty resilient. Backing is another layer of the 0.085" myrtle sides.
Evan McCartney
PostPosted: Tue Dec 22, 2009 1:44 pm
First name: Hank
Last Name: Mauel
Zip/Postal Code: 95603
Here are a couple...one simple oval and one with my initial "M" in it.
I back up the inside with .030" black fiber...bends easily and provides a nice black contrast line on the inside edge of the port.
Hank Mauel
PostPosted: Tue Dec 22, 2009 4:34 pm
I've only done one.
Backed up a laminate of maple and ebony
Made a pattern, glued it on and cut it out with my router. Cutting with the router was, by far, the most difficult step only because I was afraid I would screw it up.
Here's the rough cut
Beveled the opening with sandpaper stuck on an elliptical shaped sanding stick.
All done
PostPosted: Tue Dec 22, 2009 4:37 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I was going to do one that was a "B" (Brackett Instruments). It looked kinda like a butt because it was just the outside outline. I made it into an oval. laughing6-hehe
PostPosted: Tue Dec 22, 2009 9:35 pm
Last Name: Askins
City: Jonesboro
State: AR
This one is not finished. I used a thin veneer backing as well as the spalted maple ring all the way through. The plate with the inlay does not seal the port. It is on small seperate supports.
Chris
PostPosted: Tue Dec 22, 2009 11:38 pm
First name: Darryl
Last Name: Young
State: AR
Wow, a lot of creativity shown here. I appreciate folks showing how they've reinforced the soundport.
PostPosted: Wed Dec 23, 2009 12:25 am
Some very creative ideas shown, but.....
From what I can see in the photos showing the reinforcement backing up the soundport, it looks like the grain runs in the same direction as the sides. Wouldn't it be better if the grain orientation of the reinforcement is perpendicular to that of the sides?
Pete
Pete
PostPosted: Wed Dec 23, 2009 7:23 am
That's why I used a laminate. What you see in the photo is the outer layer of ebony. The grain of the inner layer of maple runs at 90 degrees to the side grain. Fancy plywood, if you will.
PostPosted: Wed Dec 23, 2009 10:29 am
First name: Martin
Last Name: Edwards
I put in two holes.
the sides are Ovangkohl, the supports are cherry & walnut
PostPosted: Wed Dec 23, 2009 10:42 am
This one is bound with curly maple, bunot too curly with that tight radius, backed with a cross-grain side off-cut,
PostPosted: Wed Dec 23, 2009 7:25 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
May cool and good looking ports here.
Pat, What are your procedures for installing the binding inside the port? Is it bent or cur in a whole circle or what?
Ed
PostPosted: Wed Dec 23, 2009 8:05 pm
Bent on a pipe, with Supersoft II. Takes a number of tries (i. e., failures, as in broken) with curly maple, ebony too. Maple is extra tricky because it burns easily.
PostPosted: Thu Dec 24, 2009 2:08 am
Pat, that bound hole is quite striking.
Did you start with an extra "tall" piece, which once fit into the hole could then be trimmed to match the curvature of the side?
Or rather, a piece that was the thickness of the side, and bent it to also match the side's curvature?
I hope that question makes sense! I can see either approach working...just wondered how you went about it.
