Dovetail neck setting videos on You Tube are out http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=24593 |
Author: | bluescreek [ Sat Nov 14, 2009 6:52 pm ] |
Post subject: | Dovetail neck setting videos on You Tube are out |
http://www.youtube.com/watch?v=L3YJh9OT4mw here is a link to the 1st dovetail neck setting video. I try and explain in detail all you need to know to be able to set a dovetail neck. Let me know your input . I hope you like them Thanks John Hall BCG |
Author: | Ron Belanger [ Sat Nov 14, 2009 8:14 pm ] |
Post subject: | Re: Dovetail neck setting videos on You Tube are out |
Hey John, Terrific video. It comes at an opportune time for me as I am considering moving from a bolt on to a dovetail neck joint. I really like the clarity and your common sense approach to building. Looking forward to #2. Ron |
Author: | letseatpaste [ Sat Nov 14, 2009 8:23 pm ] |
Really well done, John, thanks for posting these. Just got done watching the first two and am about to watch the rest of them. |
Author: | bluescreek [ Sat Nov 14, 2009 8:30 pm ] |
thanks for the kind works . I hope I can take the mystery out of the dovetail joint |
Author: | Fred Tellier [ Sun Nov 15, 2009 10:46 am ] |
Good videos John, you are getting quite good with you presentation skills and I like all of the topics you have covered so far. Fred |
Author: | Bailey [ Sun Nov 15, 2009 1:55 pm ] |
Great Sunday morning class for this old guy. Never to old to learn anything. Very detailed. Kent |
Author: | Haans [ Sun Nov 15, 2009 4:02 pm ] |
Very nice John! Will you do a follow up on after it's finished? Seems as though you left off with the neck a little proud of the box...do you consider glue and finish on the ribs? I usually end up dead flat on the top... or were you flat on the top also? |
Author: | bluescreek [ Sun Nov 15, 2009 7:16 pm ] |
the guitar is in the white and I like to keep ita touch proud. Once I have it finished I will set the neck and keep it about .010 above the top so that I have a true wedged joint. You need the neck joint to pull tight. |
Author: | Haans [ Mon Nov 16, 2009 7:40 am ] |
Thanks John. |
Author: | enalnitram [ Mon Nov 16, 2009 8:14 am ] |
Thanks John! I'll probably watch this one more than once. |
Author: | Philip Perdue [ Mon Nov 16, 2009 6:42 pm ] |
John, Thank you for the tutorials! They have been posted at an opportune time as I’m about to set a dove tail neck and really don’t have a good concept of it. It was a little hard at times seeing what you were describing since the camera didn’t always capture the detail. But with your help I’m sure I can move forward now. ![]() Thanks, Philip |
Author: | bluescreek [ Mon Nov 16, 2009 6:49 pm ] |
feel free to contact me through my website. I am here to help john |
Author: | John Hale [ Mon Nov 16, 2009 7:16 pm ] |
Any chance of a dvd on how you cut the joint I assume you rout yours? I watched people cutting them by hand in my evening class then gluing shims in sanding and chiselling over shooting the mark then adding another shim seemed a nightmare that's why I opted for bolt on |
Author: | bluescreek [ Mon Nov 16, 2009 7:54 pm ] |
I use cut dovetails I don't like to cut the block after the guitar is built. |
