How to Stain/Finish like this... http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=23111 |
Author: | 000lover [ Fri Jul 17, 2009 9:27 am ] |
Post subject: | How to Stain/Finish like this... |
This is a 1979 Kazuo k. Yairi Leo-J10 (for sale on ebay right now...not from me ![]() Has anyone here made a finish/stain schedule that yields a very vintage looking dark mild sunburst like the one in the pics other than 30 years of aging? ![]() ![]() |
Author: | TonyKarol [ Fri Jul 17, 2009 10:06 am ] |
Post subject: | Re: How to Stain/Finish like this... |
definitely hand rubbed into the top .. thats why it has that uneven look vs a sprayed burst ... get some different strength brown stain/dye and have a go at a spare top ... |
Author: | Flori F. [ Fri Jul 17, 2009 10:08 am ] |
You could use transtint dyes, starting with tobacco (stain color) on the outside and moving to mahogany toward the center. Dissolve in water or alcohol. I'm pretty sure there's at least one video online demonstrating how to do a burst using transtint. (edited) As Tony said...hand rubbed. |
Author: | 000lover [ Fri Jul 17, 2009 3:17 pm ] |
So, you just put on a rubber glove and wipe on the stain? Do you put anything like a couple of coats of shellac on first? I assume you rube more dark coats on the outer area and then do the same to the lighter stained area. |
Author: | meddlingfool [ Fri Jul 17, 2009 3:47 pm ] |
I did one top that way using leather dye put into rubbing alcohol. I went straight into raw wood. It was quick and easy, sort of. It was very tricky to not let it get splotchy as you went. It dries very quickly so you need to blend it swiftly as you go. Also, it stains the bindings as well, requiring scraping afterward. At the time I thought it so hideous that I gave the guitar away in disgust. Now I see that guitar all the time on stage and I gotta say, with a little bit of practice it could look very nice... |
Author: | Joe Sustaire [ Fri Jul 17, 2009 5:42 pm ] |
Hey Matthew, I do a rubbed stain finish on some of my builds. I haven't done any that dark yet but one John How did caught my eye, kinda chocolate/tobacco brown. I use the TransTint dyes diluted with water, sand the top and rub a water wash coat, (just water on a piece of rag) on it a couple of times to raise the grain and then sand it back smooth, after you get it stained like you want you can't go back and sand without changing your stained surface. Then I rub on a light film of water so the stain doesn't grab too quick and rub in my lightest color, (with another piece of rag, usually old t-shirt) then go to a darker/different color and work it around the edges. Basically a rubbed in burst, going from lighter in the center to darker around the edges. You can use water on a rag to blend your colors/tones, or rub areas to lighten, after it dries you can also sand areas that are too dark and try again. And more coats/darker tints to darken etc. You just have to play with it until you get something you like. After it dries you can rub on a shellac seal coat to protect it until finishing time. Check out John How's website, he's a master of the rubbed vintage finish. Nice to see another Okie on here, Joe |
Author: | Nick Oliver [ Sat Jul 18, 2009 5:55 pm ] |
Here's a vid about staining using the method Joe prescribes (athough the color isn't quite the same that you want ![]() |
