It is currently Sun Apr 26, 2026 1:27 am
 Post subject: Preparing fan bracing
PostPosted: Wed Jun 03, 2009 2:55 pm
My first classical so bear with me. Does profiling the bottom of the fan braces to the dome help keep the shape? Or is it just a waist of time considering their size? Does it hurt? :? Clinton
PostPosted: Wed Jun 03, 2009 4:23 pm
Crich, I believe that most people, myself included, just spring the fan braces onto the top in the solera or radius dish. When the glue has dried and the go bars removed the braces have been laminated to the top and hold the dish shape. I use the 3mm deep, 7mm wide Torres style fans and they hold the dome just fine.
PostPosted: Wed Jun 03, 2009 4:28 pm
No need to profile the fan braces. Just spring them into the top, and it will hold the shape fine.
Edit: Like Colin said.
PostPosted: Wed Jun 03, 2009 4:37 pm
Here you go, just for fun, these are pictures of my top just after gluing and shaping the braces. You can see how it holds the shape. My top is both domed and arched to the outside edges, so it's a little exaggerated, but there is nothing holding the shape but the fan braces.
PostPosted: Wed Jun 03, 2009 4:39 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
If you have any doubt, you can believe it! I was skeptical at first, too.
http://redrivercanoe.ca/
PostPosted: Wed Jun 03, 2009 5:11 pm
Cool. :D I guess I should prepare the height close to the final dimension so they spring easier. Thanks for the pictures Waddy. There's more little anomalies than I thought between steel and nylon string guitars. Clinton
Users browsing this forum: DennisK and 25 guests
