Before I go any further? http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=22024 |
Author: | J Hewitt [ Sun Apr 19, 2009 12:30 pm ] |
Post subject: | Before I go any further? |
Hello, Here's what I have done so far.....I level sanded and used Z-poxy to fill the pores (2 sessions). Sanded down with 220 between each session. Sprayed two coats of "Universal sanding sealer" , then sanded down with 320. Sprayed 5 coats of EM6000 and thats were I'm at so far. The pores appeared to look filled after the Z-poxy, but if you can tell anything from the photos there are alot of pore impressions in the finish. Should I keep spraying or sand down and start over? Or any other advice you may give?? I've never used Z poxy or sprayed my guitars for that matter....its new stuff to me. But I had fun spraying ![]() Thanks, Jeff |
Author: | Rod True [ Sun Apr 19, 2009 12:42 pm ] |
Post subject: | Re: Before I go any further? |
Keep spraying. Get at least 10-12 coats on there, let it sit for at least 1 week, 2 would be better, than level. |
Author: | J Hewitt [ Sun Apr 19, 2009 1:00 pm ] |
Thanks Rod...... |
Author: | Rod True [ Sun Apr 19, 2009 1:27 pm ] |
I should have added, that if once you've final level sanded you can always spray a few more coats if you think it's not thick enough. Make sure though that if you're going to spray more coats after the initial coats have cured, sand with 220-320 first as this will really help with the burn in. |
Author: | J Hewitt [ Sun Apr 19, 2009 3:13 pm ] |
Thanks Rod......again! ![]() |
