It is currently Fri Jul 25, 2025 3:21 am
 Post subject: removing smoke odor?
PostPosted: Fri Dec 26, 2008 9:25 am
anyone have any ideas about how to remove heavy smoke odor from inside a case , with that type of fake fur inside , and from a guitar in the "white" thanks jody
 Post subject: Re: removing smoke odor?
PostPosted: Fri Dec 26, 2008 9:36 am
I like this stuff a lot!
http://www.gaiam.com/product/eco-home-o ... +begone.do
It is clear and odorless. It truly does eliminate odors. Great with cooking odors too.
PostPosted: Fri Dec 26, 2008 5:51 pm
Last Name: Lloyd
I would give baking soda a try. It's a good odor eater, dry and inexpensive. You can sprinkle it into the guitar case and leave it closed for a few days. The guitar can be kept in the case also. With the price of baking soda you can repeat the process a number of times and vacuum up between doses.
Michael Lloyd
PostPosted: Sun Dec 28, 2008 5:16 pm
Crumbled up newspaper does a pretty good job too!
I had a case that somebody spilled a huge coffee into. I never tried the newspaper, though, because it was all plastic with a styrofoam core and synthetic fur....I just soaked and hosed it out! Worked Great!
Not recommended for wood bodied cases!
PostPosted: Sun Dec 28, 2008 8:24 pm
Someone posted on the OLF a couple of years ago that they had a guitar in for repair that someone had vomited inside of.......... If I recall correctly it was the chunky variety and a near perfect hit on the sound hole......
I would try to search for the thread but I have to go get some ice cream........ :D
PostPosted: Sun Dec 28, 2008 9:54 pm
Mmm . . . ice cream . . .
PostPosted: Sun Dec 28, 2008 11:18 pm
First name: Danny
Last Name: Vincent
I'm pretty sure hanging a clove of garlic on the inside would help. Not so good for the werewolves though.
PostPosted: Mon Dec 29, 2008 12:45 am
Put ur dirty socks and undies in the case for a few days, that oughta do it [:Y:]
If that don't work, I would try the carb soda, it works a trick. Another thing to try is to sprinkle some of that dry carpet cleaning/odour removing powder into the lining, leave it for a while and then vacuum it out again.
PostPosted: Mon Dec 29, 2008 3:17 pm
If you get really desperate you could try a car detailer - they have special deionizing stuff..
Charlie
PostPosted: Mon Dec 29, 2008 3:20 pm
Fresh cut apples in closed case
