It is currently Sun Jul 27, 2025 3:58 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 06, 2009 8:58 pm
Thanks for the tip. I have tried sealing with the shellac I use for French polishing, which is wax free, and that doesn't help. I do have non-dewaxed shellac, and I'll have to try that.
PostPosted: Mon Nov 09, 2009 9:40 am
I don't want to doubt the good people at Zinsser, but using a non-dewaxed shellac under an oil varnish (and possibly other finishes) may be asking for trouble. I'd be afraid the small wax content may prevent good adhesion.
I use the regular (non-dewaxed) zinsser shellac for most trim work when doing carpentry, it's great to seal pine knots and all, but it doesn't dry as hard as a good dewaxed shellac IME. And to my eye it is not as clear either.
Obviously I wouldn't spray the non-dewaxed shellac, it will clog the gun in no time…
Macassar ebony never presented a problem with Rockhard for me. As a matter of fact I am finishing a guitar with Macassar trim where I didn't use a sealer before applying the oil varnish, and it dried just fine.
The only woods that create a problem for me are cocobolo, EIR and generally oily rosewoods. I seal them with de-waxed shellac after wiping with naphtha, and it seems to work just fine. Another solution is to seal with a 1:1 varnish/reducer mix (Rockhard/turpentine for me), it takes longer to dry, but eventually does. The sealer coat should be a little more than a mist.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Mon Nov 09, 2009 10:16 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I use one thinned coat of zinsser shellac, non de waxed, and then 2 coats of de waxed shellac over it on oily woods. The allows the wax to seal the oily wood, but the de waxed shellac put a barrier between the wax and the finish. I may be wasting time, but I've got time.
